New Holland TN75
   / New Holland TN75 #1
farmer2009
Elite Member
Western KY
Multiple
Been looking at a used TN75 4wd and loader 2900 hrs. What are your opinions on them? Anything to look out for?
   / New Holland TN75 #2
A common problem with the TN series was leaking seals associated with the 3PH lift arms. Chances are that the seals have been replaced on a tractor with 2900 hours.
Steve
   / New Holland TN75
Thanks SMS. Are the seals on the top housing where the lift rotates? Or is it internal? I see you have a TN series. How do you like it?
   / New Holland TN75 #4
Here are two threads that discuss the problem: http://www.tractorbynet.com/forums/new-holland-owning-operating/241318-tn75-hydraulic-leak-3pt-resevoir.html and http://www.tractorbynet.com/forums/new-holland-owning-operating/241014-tn70-name-part-post2810080.html#post2810080.
I have been satisfied with my TN 55, but I have put only 310 hours or so on it since I purchased it new in 2000.
Steve
   / New Holland TN75 #5
I've got a tn75 2009yr. So far so good. Maybe 900 hours. Snowblowing , bush hogging, and some fel work.
   / New Holland TN75 #6
I've got a 2003 model with around 2500 hours. Only thing replaced was the clutch at about 2200 hrs. 3pt seals just now started leaking. I've been happy with the machine. Mainly used for cutting hay, brush hogging, plowing and FEL work.
   / New Holland TN75 #7
what kind of transmission does it have? the shuttles that use a computer (on the dash), the computer have been known to fail at some point also having the automatic 4x4 has a weak computer too. i have a 2005 tn75 with super steer, fel and about 800 hours. i absolutely love the tractor. ive owned it about a year and when i bought it the previous owner had replaced both computers before it bought it. $800 per
   / New Holland TN75
It has a 12x12 shuttle transmission. Not sure if it has the computer or not. I like the looks of the tractor but think I am going to look a little more as I would like lower hours. But I know I want the 12 speed instead of the 8.
   / New Holland TN75 #9
Mine has the 16x16 with mechanical shuttle. Both work very well. IMO, the 16x16 option is worth more.
3ft Metal 5-Point Star Art (A55853)
3ft Metal 5-Point...
Freightliner Tender Truck - Adams Tender (A55301)
Freightliner...
2015 Volkswagen Jetta Sedan (A55758)
2015 Volkswagen...
2009 Freightliner B2 School Bus (A55852)
2009 Freightliner...
Forklift Safety Basket Attachment (A53421)
Forklift Safety...
2021 Allmand Bros Maxi-Lite II 20kW Towable Light Tower (A55973)
2021 Allmand Bros...
