755 john deere
   / 755 john deere
I didn't check the glow plugs . The return line from the injectors is dry . I'm thinking I'm not getting enough fuel . It blows a white smoke ,but will not start. Yes it did just kill. It started back and ran for about 2 minutes and that is it . Compression is good. Thanks for the come back.
   / 755 john deere #13
Did you actually check the compression with a gauge? or does it just appear to be "good".
   / 755 john deere
I pulled the rubber line from the Injector, and it's dry. All suggestions are appreciated. Thank you.
   / 755 john deere
I did not check the compression with a gauge , with a new battery, it doesn't take too much cranking before the battery wears down. I will put a compression gauge on it today. I appreciate the come backs. All suggestions are appreciated. Thank you.
2014 Ford Taurus AWD Sedan (A56859)
2014 Ford Taurus...
TREE PLANTER (A52708)
PALLET LOT OF CLOSET DOORS & SHELVING (A58374)
PALLET LOT OF...
5' MOWER (A52706)
5' MOWER (A52706)
TRUCK MOUNT TOOL BOX W/ SAFETY WORK SIGNS (A52708)
TRUCK MOUNT TOOL...
SKIDDED FRAC TANK (A55745)
SKIDDED FRAC TANK...
