Transmission oil for Gravely 12 Professional two wheel tractor
   / Transmission oil for Gravely 12 Professional two wheel tractor #1
seacookie
Allentown, Pa
Gravely 12 Professional walk behind
Recently purchased a Gravely 12 hp Professional two wheel tractor; probably one of the last ones built, but there is no model or serial #'s on the machine. It has only 250 hours on it. I was checking fluids via dipstick which revealed a foamy green oil in the transmission. A downloaded manual and one dealer I spoke to said it should be 10-30 motor oil. I drained it thinking there might be water in the oil only to find that the oil is definitely not motor oil I'm used to seeing, it was green and it's consistency reminds me of Red line synthetic high performance gear oil (which is blue not green) used in auto gearboxes in performance cars. Now I'm thinking I shouldn't have drained it. Does anyone know if they changed the oil spec in later years? If so what should it be. Thanks!
   / Transmission oil for Gravely 12 Professional two wheel tractor #2
service manual says SAE 30, 5 qts
   / Transmission oil for Gravely 12 Professional two wheel tractor #3
Might want to repost on the two wheeled tractor forum. A lot of those guys have Gravelys
Thanks, the chart with specs was quite helpful. Maybe the previous owner put something else in the trans, but I have no way of knowing.
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2016 JOHN DEERE 3032E LOT NUMBER 94 (A53084)
2016 JOHN DEERE...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A53426)
2007 POWERSCREEN...
(4) STEEL CARTS (A51248)
(4) STEEL CARTS...
2014 FREIGHTLINER 114SD VACUUM TRUCK (A51406)
2014 FREIGHTLINER...
UNUSED FUTURE FT2P 12 VOLT PUMP (A51248)
UNUSED FUTURE FT2P...
