How do you store you logging/tow chain?
   / How do you store you logging/tow chain? #101
Big plastic cat litter container. Dump the chain in, spray with WD40, and leave it until I need it again.
In error, I left a chain out and it got all rusty and that bothered me. I put it in a 5 gallon bucket, sprayed it with a 30%-70% mix of clean oil and diesel fuel, let it sit for a few days and it now looks as good as ever, is rust free and makes me feel better.
   / How do you store you logging/tow chain? #102
You can line your Tube holes in your loader with cpvc and make caps for ends. then put you chain in there.
   / How do you store you logging/tow chain? #103
Well I certainly found some good ideas in this thread and thought I would take advantage of one. I used 4" PVC pipe and put the cap on the bottom with 2 small screws. I figured it would be just a matter of time before I would drop something in there that I couldn't reach or it would fill up with dirt and debris that I would want to empty it out so I didn't want to glue the cap to the bottom. I have 3 chains stored in it, that should be enough for most cases, if not it will be a trip to the barn.
   / How do you store you logging/tow chain? #104
   / How do you store you logging/tow chain? #105
You can also just hook you chain behind something and drag it around for a few mins and all the rust will be gone . A dirt drive works the best and only takes a few mins .
Sent from my iPhone 5 using TractorByNet
   / How do you store you logging/tow chain? #106
Looks good. How did you secure the pipe to the loader frame?
   / How do you store you logging/tow chain? #107
Velcro dots! :D <jk>
I liked the orange chain so much I went searching at Lowes on-line. Item 348436 ($32.98) has the hooks:
Shop Blue Hawk 12-ft Welded Orange Chain at Lowes.com
and item 348268 ($3.34 / foot) is just the chain (looks to be a different orange)
Shop Campbell Commercial 1-ft 5/16 Welded Hi-Visibility Orange Steel Chain (By-The-Foot) at Lowes.com
   / How do you store you logging/tow chain? #108
Hang the spare "tow" chain off the safety screen and the chokers off the winch.
   / How do you store you logging/tow chain? #109
There was a bolt hole at the top and I drilled another at the bottom, had enough clearance that the loader does not hit nuts on backside. 1" bolts and nylocks worked great.
   / How do you store you logging/tow chain? #110
2025 JMR Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A56857)
2025 JMR Single...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
Toro Dingo Mini Skid-Steer Mounting Plate (New/Unused) (A59225)
Toro Dingo Mini...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A56436)
2023 Kubota U48-5...
TABLES & WOODEN BENCH (A58374)
TABLES & WOODEN...
2009 PETERBILT 340 WATER TRUCK (A58214)
2009 PETERBILT 340...
