ford 4610
   / ford 4610 #1
tractorboy3011
Hi my ford 4610 has trouble starting off in gears higher than low one i adjusted the biting point on the clutch but it didnt do anything any ideas?
   / ford 4610 #2
Can you be more specific with describing your problem? Does the engine die, does the tractor shudder..... I flunked Mind Reading 101-ask my wife!
   / ford 4610
Well the engine stays running but goin on flat ground it takes a lot of revs to get rolling as if the handbrake was on(but i know its not stuck on)
   / ford 4610 #4
What rpm are you starting out with? Is the clutch slipping? Do you smell anything like a burned clutch? Any sign of oil dripping from the bell housing? How do you know the brakes are not stuck?
   / ford 4610
Idleing rpm but to get moving needs high rpm.no smell or oil.i know the brakes arent stuck on as it acts normal in lowest gear.
   / ford 4610 #6
What are you talking about regarding "...high rpm to get moving..."? Idle is about 700-800 rpm So what does it take to get you moving? max rpm is ~ 2200rpm so you have between say 800 to 2200 rmp working range.
   / ford 4610 #7
What transmission do you have? Shuttle or standard 8x2? Sent from my iPhone using TractorByNet
   / ford 4610
Standard but its 4 gears a range(hi,lo,reverse)
   / ford 4610 #9
8 forward and 2 reverse total correct? Also do all gears other than 1st slip or is it just certain gears?
   / ford 4610
8 forward four reverse and it only starts moving right in lowest gear.could it be the clutch?
John Deere Tractor Weights (A57149)
John Deere Tractor...
Jumbo Quartz Slab 127.5" x 63.75" (new/unused) Est. Retail $2,200 (Pickup Location: Atascadero, CA) (A59225)
Jumbo Quartz Slab...
*Selling at Royal Auction Zephyrhills, FL Location* (A59228)
*Selling at Royal...
UNUSED FUTURE CAT 305 44" EXCAVATOR RAKE (A58376)
UNUSED FUTURE CAT...
LENNOX 4 TON AIR CONDITIONING UNIT (A58376)
LENNOX 4 TON AIR...
(2) RAM 2500K 2 SPEED LANDING GEAR (A58376)
(2) RAM 2500K 2...
