Selecting a quality enclosed trailer
   / Selecting a quality enclosed trailer #11
Aluminum is not much a weight savings. A I have one. It's 1,350# and a comparable steel is 1,600#. The savings is rust prevention. That being said I have 3 trailers and the other two are steel. My next purchase will be steel.
Chris
   / Selecting a quality enclosed trailer #12
If you are looking at trailers that are under 7,000 pounds, aluminum is a good option. When you start getting into the 10-12K range, the aluminum trailers really get bulky In order to hold up to big tongue loads and weight shifts that HD trailers regularly see. Our local rental yard has been using the same fleet of Aluma brand enclosed trailers for the last 10 years and they are holding up quite well considering the abuse they get. I would also recommend getting a V-nose trailer (your truck will thank you).
   / Selecting a quality enclosed trailer #13
I would advise going with the lowest height practical for you. I say this because I just arrived in Florida for a vacation, having towed a 7x14 American Hauler Night Hawk. Inside height of the trailer is 7'. It has a slight V nose. My 2013 F150 5.0 got 8-9 MPG pulling it. I knew the mileage would drop considerably, but did not think as much as it did. The 6 speed spent most of its time in 4th. I think the resistance from the extra height and not as acute of a V nose was a big culprit, but maybe I expected too much from the 5.0. The trailer had just under 1400 pounds of motorcycles and luggage for 2 in it.
My business trailer is a 7x18 Kristi. Only 6' high inside. Sharp V nose with front & rear ramp doors. It pulls much easier & smoother than the 14' AH. As soon as I'm home from vacation, the AH is on Craigslist. I've already been in touch with my Kristi dealer about a 7x14.
   / Selecting a quality enclosed trailer #14
I would advise going with the lowest height practical for you. I say this because I just arrived in Florida for a vacation, having towed a 7x14 American Hauler Night Hawk. Inside height of the trailer is 7'. It has a slight V nose. My 2013 F150 5.0 got 8-9 MPG pulling it. I knew the mileage would drop considerably, but did not think as much as it did. The 6 speed spent most of its time in 4th. I think the resistance from the extra height and not as acute of a V nose was a big culprit, but maybe I expected too much from the 5.0. The trailer had just under 1400 pounds of motorcycles and luggage for 2 in it. My business trailer is a 7x18 Kristi. Only 6' high inside. Sharp V nose with front & rear ramp doors. It pulls much easier & smoother than the 14' AH. As soon as I'm home from vacation, the AH is on Craigslist. I've already been in touch with my Kristi dealer about a 7x14.
Has nothing to to with the nose, it's the back that creates all the drag. Look at any commercial jet airplane. It's blunt in the front but tapered to a point in the tail. You can see the eddies of drag if you drive a boat at 5 mph through the lake. Watch the back end, it has currents of turbulence which creates drag. This is the same for any object that moves through air or water. Look at a racing yacht (sailboat), or one of them 6 man rowing boats, they are tapered in the back. Same with a Formula One Car or Indy Car.
That trailer would not have mattered if you had 6500# in it or the 1400# you had, you are only going to get 8-9 mpg pulling it. I have a Bachelor a Degree in Aero Space and a Masters in Aeronautical Engineering. I have spent nearly 10 years studying aircraft design, automobiles, boats, and about everything else that moves through air or water and it's always the same answer. A tapered tail gives much more return on investment then a tapered front by about 5 fold!
One other trivia fact. We did a comparison with a solid 5' tall by 7' wide gate on a trailer. It had less drag at a 75deg angle vs a mesh gate of the same size set at a 75deg angle.
Chris
Thanks for the help, is the type of frame a relevant consideration? I see everything from Tubular to I beam to channel.
I'm towing with a 3/4 ton truck so weight isn't a huge consideration. I have thought seriously about a 10000 lb trailer just for a safety factor.
   / Selecting a quality enclosed trailer #16
Chris - On the trip down I noticed some tractor trailers (van trailers) with some kind of device on the rear of the trailer. I don't recall the brand name, but apparently the intent was to change the aerodynamics at the rear of the trailer.
Also, I've heard several guys swear that a flat nose enclosed trailer pulls better and sways less in the wind thn a V nose. All I know from personal experience with the 4 enclosed I've owned is that the lower profile/sharper V pulls better than the others did.
   / Selecting a quality enclosed trailer #17
I'm not a fan of tubular. It rust from inside out and by the time it shows its face it's too late. I personally have one of each of the 3 you listed. But far my favorite is the channel for its finished appearance, strength, weight trade offs.
Chris
   / Selecting a quality enclosed trailer #18
Yes, many new semi trailers and high end campers are now using skirting and air deflectors in the rear to smooth out the air disturbances. For a trucker a 3% increase driving 500 miles a day at 7 mpg with diesel at $4 per gallon would equate in $20 per day savings or 1/2 mpg better with that meager 3% increase.
Chris
   / Selecting a quality enclosed trailer #19
Chris
Not likely, but maybe an option:
Enclosed Car Race Trailers
   / Selecting a quality enclosed trailer #20
I have a Haulmark aluminum shell and steel frame 7x14 7' inside height enclosed rounded front trailer. I pull it with my 1997 Dodge 2500 Cummins.
Empty I get 15.5 mpg and loaded I get 14.5 mpg. I think the trailer is 8' 4" high.
2010 MULTIQUIP 25KW GENERATOR (A55745)
2010 MULTIQUIP...
2011 JOHN DEERE 544K WHEEL LOADER (A52707)
2011 JOHN DEERE...
2025 Poly Fuel Tank with Electric Pump (A55852)
2025 Poly Fuel...
2016 Ford Explorer AWD SUV (A55853)
2016 Ford Explorer...
2012 Chevrolet Silverado 3500 HD Enclosed Knapheide Service Truck (A55973)
2012 Chevrolet...
70pc. 12ft.x 3ft. Black Metal Roof Panels (A55758)
70pc. 12ft.x 3ft...
