Electrical wiring question
   / Electrical wiring question #1
crowbar032
Gold Member
Moores Hill, Indiana
MF 150, TO-35, John Deere 5065E, Caterpiller 953 track loader, NH LS170 Skid Steer
So I ran an underground wire to one of my sheds off of another electrical box. I installed a new small breaker box in the shed, it only has two breaker slots. Its the weirdest thing though. One of the breaker slots work perfectly, but the other does nothing. I've switched the breakers and wires around and no change. The slot on the left of the box works, but the right doesn't. What in the world could I have done wrong?
   / Electrical wiring question #2
how many wires wire in the line you ran? what color are they? did you run a neutral?
   / Electrical wiring question #3
Normally the left breaker (if 120 volt) will be on one leg of the 220 to Neutral and the other breaker will be on the other leg of the 220 volt to Neutral. You did run 3 wires Hot Neutral Hot to this other box correct? and you did measure to see that you have 220 volts between the legs and 120 volts from each leg to Neutral, correct?
If all of that is correct, take both breakers out and inspect where they connect up to each leg.
   / Electrical wiring question #4
A photo would be worth... oh, about a thousand words...:)
   / Electrical wiring question #5
That's why I asked how many wires were ran..
   / Electrical wiring question #7
yup....i can see it right now. one side of the panel has no power. If you want to keep it 120 volt but have 2 circuits, you can jump both sides of the main. however if you only ran 20 amps to the panel, you wont have any benefits of having 2 separate 20 amp circuit breakers.....you still have only 20 amps , 120 volts going there...need pics, wire size info, wire type info, what sized service you ran and how large of a service you are feeding from.
   / Electrical wiring question #8
I ran 3 wires. Pic should be attached.
   / Electrical wiring question #10
It looks like the breaker on the right goes to where the white neutral wires are??????? maybe it's just the way the photo looks I hope!!
2004 Sterling Acterra Cab and Chassis S/A Truck (A55852)
2004 Sterling...
2007 FORD F150 XL EXT CAB TRUCK (A51406)
2007 FORD F150 XL...
2003 Pierce Spartan Pumper Fire Truck (A55852)
2003 Pierce...
Adams 5 Ton HC Spreader (A55301)
Adams 5 Ton HC...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A55787)
2025 Kivel 48in...
2005 INGERSOLL RAND SD-70D TF SMOOTH DRUM ROLLER (A52706)
2005 INGERSOLL...
