Fence post types
   / Fence post types #11
Every wooden post that I've ever seen that rotted out was because there was a low around the base of the post where water stood after it rained or the area was watered. For a wood post to last, water must drain away from the post. What happens is the fill that goes in around the post either settles if it was dirt, or the concrete is only brought up to ground level and once the grass grows back, that area becomes the low area. You have to mound the dirt or concrete up and if you use dirt, you have to go back and check it periodically. Usually after a few months and several rains it's done settling, but just like everything else, keep an eye on it and fix it when it needs more dirt.
Eddie
What Eddie said:thumbsup: Even metal will suffer from standing water, you have to drain water away from the base of a post. Even electric companies installing T-poles, will mound some of the dirt up around the base.
You can use the t-post kit for corners, but if you want more strenght, weld or have welded the corner braces, gate brace and "H" braces you need out of a medium walled 2-3/8 or 2-7/8 pipe. You can use railroad ties, or cut telephone poles and brace them in the traditional manner if they are available localy and use t-post for all the line post.
   / Fence post types #12
I have 1.5 miles of 5 strand barb wire fencing around the property. I'm 99% 133 T-post. For the corners I've made rock gabions out of steel pallets and expanded steel. They are 4'x4'x4' and when filled with rock they will definitely anchor the fence corners. My fence crosses a "moat" which runs between my two lakes and the T-posts in this area are dissolved by the extremely alkaline water in the big lake. These post must be replaced - on an average - of every 8-10 years. I'm trying an alternate to T-posts in the moat area. I'm now using cedar fence posts - about 2x to 3x the cost of steel but they are said to last at least four times longer. We will see - the cedar posts have been in the ground 12 years now and show no signs of rotting.
   / Fence post types #13
I have had cedar posts that did not last more than 5 years.
I have not had problems (so far) with good treated fence posts. We have been here 12 years now. Last year I pulled out some treated posts that had been backfilled with dry concrete (and some with wet concrete). They were in excellent condition and, after pounding off the concrete, I will use them again.
Of course, for corner and gate posts, bigger is better and used telephone poles are great. There is a farm supply store about 40 miles from here that sells sections of old poles.
I'm not sure what the secret is. It well could be mounding the dirt up next to the post.
   / Fence post types #14
Another good idea I use on wooden post, at a minimum, I will cut an angle and then paint or oil the top to keep water out. I have also use tin cut to cover the top, but it is a bit more time consuming.
   / Fence post types #15
T posts don't last quite so well near the coast...
   / Fence post types #16
I agree that any type - wood or steel or cement - post is going to have trouble in the water. About 8-10 posts in my moat area are continually in wet ground and for 2-3 months per year the moat area is flooded and these post bases are under water. The very best "post" I've found is a railroad tie. Its drawbacks are cost and weight. I have no idea what a 10" tie weighs but I can not lift one by myself into a post hole. The soil and water in our lakes in this area can be VERY alkaline. I know this alkaline condition is what causes the problems with the steel T-posts in my moat area. The neighbor, down the way, tried new cement RR ties in a damp area and they dissolved like candy in a child's mouth. I'm just hoping the cedar posts in the moat area last longer than steel and I don't have to go to RR ties.
   / Fence post types #17
My one and done end cap and corner post. Solid as a rock.
   / Fence post types #18
Every man to his own liking, but I much prefer treaded wooden post. I use 4.5 to 5.5 wooden line post (driven) and utility post for the corners (range from 12" to 20"). I have never have a good quality thread post rot out in 10 years. A metal post may last longer, but around here T post tend to fade in the sun and rust. Nothing look worse to me than a bunch of rusty metal T post, so I will replace the wooden one's when they eventually rot.
Our latest fencing project will have nearly 10 miles of new fence and all the post will be wooden, but that's my preference.
   / Fence post types #19
We only have a gate across the road but it is made from 4x4 and 6x6 .4 PT CCA wood. The gate has been up almost 14 years and is in good shape even though one side is very, very wet. The posts even held up when a bulldozer hit the gate and dang near pulled the gate off the hinges. The posts are fine. The gate and hinges, not so much.
T Posts that are the same age look like scat since the tops have rusted. Having said that, if we built a property line fence, I would use T posts with .4 PT ACQ as corners and brace posts.
Our ground is clay and rock or rock and clay if a post is required. The ground stays wet during the winter and only dries out when the temp's go up and the trees start drinking again. By wet I mean, if I drive the tractor is most areas, I can make a huge rutted up mess do the saturated ground.
Later,
Dan
   / Fence post types #20
My 7.5" x 7.5" x 8' concrete and rebar fence posts weigh 500 lbs each and cost a little over $30, but they will last for generations. RR Ties are close to $20 and not very good quality these days. They last me 20 years. Cedar maybe 8 years.
2016 Autocar Xpeditor T/A New Way Side Loader Garbage Truck (A51692)
2016 Autocar...
377811 (A48836)
377811 (A48836)
UNUSED LANDHONOR LHR-MS0608 METAL SHED (A54757)
UNUSED LANDHONOR...
CONCRETE MIXER ATTACHMENT FOR MINI SKID STEER (A53421)
CONCRETE MIXER...
2013 John Deere 650K LGP (A47477)
2013 John Deere...
RV Hitch (A50121)
RV Hitch (A50121)
