Mahindra 3316 fan and radiator shroud
   / Mahindra 3316 fan and radiator shroud #1
seal oil
nfld canada
2010 mahindra 3316 shuttle tlb
The fan has about 1/2 to 3/4 inch clearance from the shroud on the top but is close to touching on the bottom . Is there any way to adjust the shroud so that it has equal distance on top and bottom ? I slackened all 6 shroud bolts to see if it could move down but the holes are round .
Does anyone have a service manual for the 3316 gear model ? The reason I ask is I am wondering if there might be anything in it on how to fix this problem . If it is I can buy one .
   / Mahindra 3316 fan and radiator shroud #3
That type of a issue is normally a owner preference. The manual would not tell you to egg the holes to get it centered so the blades won't hit.
   / Mahindra 3316 fan and radiator shroud #4
It is surprising the holes aren't already egged. Perhaps a batch of shrouds were made without the full machining process. What is curious is this tractor didn't have fan clearance problems when it was new. Am I right about that, seal oil?
Thanks AchingBack . Not sure because I am the second owner . It was traded in at the dealer where I bought it with 229 hrs on it . I am 400 miles round trip from there and my car hauler needs work before I could take it on such a long haul . I checked the holes in the shroud to see if they were egg shaped but they are round . That is why I am wondering if there is another way to adjust it .
Thanks art . I thought about doing that but it don't look like it would be easy getting the shroud off .
It is strange for not to have any way to make any adjustment . Do anyone know where I might be able to buy a service manual ? It might have something in it on how to adjust it .
Honda EU3000is Gasoline Companion Inverter Generators (A51691)
Honda EU3000is...
2001 Dodge Ram 3500 4x4 Knapheide Flatbed Truck (A51692)
2001 Dodge Ram...
2001 CHEVROLET TOW TRUCK (A52472)
2001 CHEVROLET TOW...
2007 Hino 268 Cab and Chassis Truck, VIN # 5PVNJ8JV672S50269 (A51572)
2007 Hino 268 Cab...
LOAD OUT AND SHIPPING (A51572)
LOAD OUT AND...
LMC LOT NUMBER 144 (A53084)
LMC LOT NUMBER 144...
