john deere 445 thermostat gauge goes right to hot on start up
   / john deere 445 thermostat gauge goes right to hot on start up #1
rolandj
NJ
1960 JD 440 ID, 1999 John deere 445 lawn tractor w/ loader, 2004 Kubota bx 23
I just got tractor out of winter storage and started it up and had a problem with it getting hot. I replaced thermostat and coolant now soon as I turn key on the gauge cycles and goes right to hot when machine is cold . The gauge isn't stuck. I started mower and let it run with blades on up to temp no lights come on. I am thinking it is the sensor in block. If it is can I get one at local auto parts and does anyone have a part # thanks
   / john deere 445 thermostat gauge goes right to hot on start up #2
its possible you might have the same issue I had. when i engaged the pto my temp gauge pegged and all the instrument lights went dim. the deck will not engage if the tractor is really hot so you are safe. Turns out the black ground wire on the instrument panel had a bad connection. remove the left guard and there is a plug on the instrument panel. little difficult to get to but it shows how to remove the instrument panel in the manual to replace the lights. I checked the plug to make sure it was grounded and took a small screw driver to make sure the receiver was closed to make it connect to the pin on the dash panel. Plugged it back in and fixed all my issues. Hope this helps.
   / john deere 445 thermostat gauge goes right to hot on start up #3
You need to 1st find the sensor and make sure it's plugged in.
I think it's on the engine top front pointing down.
You need to pull the wire off and see what happens with it loose.
I would get the sensor from JD if it's bad, but I don't think they fail often. (Possibly # M117054 ~ $48)
You may find the wire shorted someplace.
LAMAR 20 T/A TRASH TRAILER (A50854)
LAMAR 20 T/A TRASH...
1999 FONTAINE 48X102 FLATBED TRAILER (A51222)
1999 FONTAINE...
2021 Caterpillar 304E2 Mini Excavator (A50322)
2021 Caterpillar...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A52128)
Neckover GL24-2-7K...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
2021 Kubota RTV X900 4x4 Utility Cart (A50322)
2021 Kubota RTV...
