MoPops
- Joined
- Mar 9, 2014
- Messages
- 1,306
- Location
- Center, Mo (small town, it exists)
- Tractor
- Bobcat CT225, John Deere X540
I bought a old 5' Mohawk brush cutter. It came with a three foot PTO shaft, when I first hooked it up to my Bobcat CT225, it was very apparent the PTO shaft was too short. The guy (junk dealer, I'll call him) I bought it from is going to extend the male portion of the PTO shaft by 6". I think that would be enough.
Question, I noticed (I'm a total rookie at all this by the way) that newer PTO shafts are enclosed in a cover. When those shafts are rotating, does the cover rotate also?
I can certainly see the safety benefits.
Question, can you buy the cover separately, and get them to fit over a older PTO shaft?
When I test ran the brush cutter, with the too short shaft, I could see and hear the shear pin plate hitting the arm for the brush cutter that goes up to the upper arm of my three point hitch, when I lowered the three point hitch down, the arm angle changed, and wasn't hitting the shear pin plate. However, it forced the rear wheel on the brush cutter down hard on the ground.
If I wanted to knock down taller brush, and not cut real low, I'd like to run the brush cutter up a little higher (I think) the only way around this plate hitting the arms was to raise the arm going up to the top arm of the 3 pt hitch. I haven't tried it out yet, as I haven't got the lengthened shaft for the PTO yet.
So, the question is; does the rear wheel of a brush cutter need to be on the ground?
I didn't think so, but I'm not sure..
Sorry for the lengthy post. I hope I've explained the situation with the knocking and spinning of the PTO shaft and shear pin plate well enough so that someone can understand what I'm asking.. :confused2:
Thx
Jeff
Thx
Jeff
