Slightly bent rime - tube candidate?
   / Slightly bent rime - tube candidate? #1
newbury
Super Star Member
From Vt, in Va, retiring to MS
Kubota's - B7610, M4700
My M4700 needs new front tires to replace the dry-rotted ones, best price I've found for the 9.5x22's from a local dealer was about $300@.
BUT - one rim is slightly bent (disc is fine). They want about $400 for the rim.
I'm thinking tube the tire for $85 instead of replacing the rim?
Does this make sense? Any problems to be aware of?
I don't expect to use the tractor for more than a few hundred hours per year.
   / Slightly bent rime - tube candidate? #2
That is what I did to my slightly tweaked rim.
   / Slightly bent rime - tube candidate? #3
hammer it out
   / Slightly bent rime - tube candidate? #4
Go to a real tire store and they will tell you who can repair the rim. Google rim repair and search for someone in your area. If it is not real bad put a tube in it. Check a tractor bone yard. It is easier to get this stuff now because of the net.
Turned out to be a non-issue. Worker bees figured they could hammer it out and when I told the sales guy I wanted a tube he said they ALWAYS install a tube and that was included in the quoted price.
About 3 years ago I called about EVERY REAL tire store in the area. The ONLY tractors they dealt with were the type pulling 55' trailers down the interstate.
36" Smooth Excavator Bucket (A50774)
36" Smooth...
2006 International 4400 DT466 (A50120)
2006 International...
(4) Beams (A50121)
(4) Beams (A50121)
JOHN DEERE 3040 TRACTOR (A50459)
JOHN DEERE 3040...
2003 Maverick Pathfinder 2200V Center Console Fishing Boat with T/A Boat Trailer (A50324)
2003 Maverick...
Toro Workman Utility Cart (A51694)
Toro Workman...
