Husqvarna Chain Saw-chain races at idle
   / Husqvarna Chain Saw-chain races at idle #1
jodebg
New Hartford, CT
Kubota B-2650
I have a Husky Model #345.
I've been having an intermittent problem
with the chain racing at idle.
It seems to run fine for a while and then begins
to idle at higher speed and the chain races.
When it is warm this issue comes and goes-
sometimes drops to low idle with no chain
movement and the next time I stop cutting
the idle stays elevated and chain races.
How should I approach this issue?
   / Husqvarna Chain Saw-chain races at idle #2
Adjust your carb, had the same issue with mine.
   / Husqvarna Chain Saw-chain races at idle #3
Check for an air leak . Check to make sure the carb has not vib. loose, or that a rubber hose is not cracked and leaking.
   / Husqvarna Chain Saw-chain races at idle #4
If it only happens when the saw is warm to hot, I would look for an air leak, perhaps at the carburetor mounting area. While it is happening, spray carb cleaner or wd40 around the base of the carb. If it slows right down, you found the leak. If it also happens when the saw is cold to cool, then adjusting or cleaning the carb would be in order. Saws usually idle fast on overly-lean fuel/air mixtures.
   / Husqvarna Chain Saw-chain races at idle #5
Agree, carb or air leak at carb, or cracked vacumn line. Clean your air filter thoroughly too, and report back results.
   / Husqvarna Chain Saw-chain races at idle #6
Sounds like a classic air leak!
Don't procrastinate, 2 cycle engines running lean will melt the pistons. Don't ask how I know how much a piston and cylinder for a chainsaw costs....
Craftsman LT2000 42in. Riding Mower (A49346)
Craftsman LT2000...
2007 JOHN DEERE 624J WHEEL LOADER (A51406)
2007 JOHN DEERE...
1998 Kenworth Tandem Grain Truck (A50514)
1998 Kenworth...
2018 CATERPILLAR 249D TRACKED SKID (A51222)
2018 CATERPILLAR...
2015 CIMC 40FT CONTAINER CHASSIS (A52141)
2015 CIMC 40FT...
2012 FORD F-550 SUPER DUTY XLT SERVICE TRUCK (A51406)
2012 FORD F-550...
