/pine
Super Star Member
- Joined
- Mar 4, 2009
- Messages
- 12,450
You might check the rental prices for a vibratory plow...also they make an attachment for a sub-soiler to lay cable...
Also on on related note, don't forget that when you stick a copper cable in the ground, you have upped your risk to take a lightning strike (transient) on that cable. You will need to consider surge protection designed for Ethernet and coax cables. Some areas of the country have many more strikes than others, but it should be considered in all installations.
Now you tell meI connected my parents' and aunt's home together using coax and an ethernet-over-coax box. A lightning strike took out both boxes and about half my aunt's PC equipment.
I have always known. All you had to do was just ask me!Sorry to hear about your strike, they can be devastating. Most people don't realize that for every lightning strike you see in the air, that earth currents flow from all directions in the ground to equalize that strike. When current flows in the earth, then any conductor in the ground will have a voltage induced in it from these flowing earth currents.
What can you do about buried power feeder lines? For example, I have 300' of 10-3 copper running underground to my pier, and 100 feet of 1/0 aluminum running underground from my generator. Any way to mitigate possible effects of a strike?
Be aware that not all cat5 etc cable is waterproof. If it is direct buried, it should be rated for this.
