jeff9366
Super Star Member
- Joined
- Jan 14, 2011
- Messages
- 12,777
- Tractor
- Kubota Tractor Loader L3560 HST+ ~~~~~~~~~~~~~ 3,700 pounds bare tractor, 5,400 pounds operating weight, 37 horsepower
Thanks for the replies. If I did go with the chain method, what size chain is required?
If the chain broke, could it pop back and hit the person in the tractor?
5/16" Grade 70 chain is correct. The best price is a 20' length of same at Lowe's or Home Depot in Hardware section, subsection Towing. It is sold with a Grade 70 Grab Hook on each end. You probably want to remove one grab hook and substitute a Grade 70 slip hook. Slip hook makes it a choke chain. (Post #4)
Lowe's and Home Depot chains come in a plastic pouch.
Chain will not snap back if it breaks. One link may lob a short distance, but the rest will drop to the ground. This is why chain is used rather than steel cable or synthetic straps, which will snap back if they break and can kill or maim someone in the process.
Keep chain from concrete contact. Even the strongest chain will abrade pulled across concrete with a load pressing it against the road.
Once you free the trees do not drag them flat on the ground. If flat, and tree hits a rut or boulder and stops, the tractor will rear up on its back wheels in 1/2 second. (Ask me how I know.)
Elevate the end of the tree nearest the tractor at least 8" before dragging.
