Moving Felled Trees
/ Moving Felled Trees #21
....your tractor couldn't pull more than it's own weight? I don't think that's right.
Not at all. But let's say you are pulling a 10,000 lb cart from your drawbar. How much force is on the chain? Not 10,000 lbs, unless you have a pully and are lifting the cart up a 90-degree incline, right? To put it another way: I weigh 200 lbs, but I can roll a 6000 lb car on level ground. Would you conclude that I can lift 6000 lbs?
My argument is that the tractor is unlikely, under real-world conditions, to be able to apply more force to its draw-bar than its own weight--unless you were to get a runup and snap the chain taut. Using the tractor's own weight as a guideline is arbitrary. According to BCP's post, it sounds like 132% of the tractor's weight would be a more conservative best-case estimate.
/ Moving Felled Trees #22
I have no idea of how much drawbar pull my tractor has, but I can tell you this, I would be extremely happy if my tractor could pull in a straight horizontal pull as much as the tractor weighs. It might do it, I just have no way of measuring it.
/ Moving Felled Trees #24
The Nebraska tractor tests actually documented that figure on the older iron. As I recall, an 8N was rated around 2,800lbs of draw bar pull, and an NAA (Jubilee) was around 3,200. So, they were higher than, but in the ballpark of their weight without ballast.
/ Moving Felled Trees #25
I I could pull 6000 lbs. (which is about what my tractor weighs with loader tires, loader and bucket, and ballast on 3pt, that would be a lot.
I have a frame mounted back hoe on my tractor. Would I need to remove this in order to hook up a clevis?
/ Moving Felled Trees #30
We were talking about this in another thread last night. I saw an antique tractor pull on TV. The winner pulled 135% of his weight. I think it was a stock class but hard to tell what was done to the tractor.
It comes down to the coefficient of friction between the tractor tires and the ground. A big tractor on glare ice can't move itself but a tractor on a good surface and the right tires can pull until it runs out of horsepower to turn the wheels.
/ Moving Felled Trees #31
And it depends on the stability of the soil and the traction of the tires, direction of the pull (i.e. the load pulling down on the axle) .
Note those old tractors may have pulled, 135% of their weight, but were they comparing to the weight on the sled, or the force in the chain? As others gave noted, you can pull many times your weight if there's little friction between that weight and the ground.
However, I would think that a 1hp 300lb , could exert tons of pulling force if geared low enough and big lugged or steel tires being pulled downward "into" the ground to get traction.
/ Moving Felled Trees #32
One horsepower equals 550 foot-pounds per second, meaning you can raise 550 pounds one foot vertically in one second or one pound 550 feet vertically per second. If you had a 10,000 lb load and had frictionless gearing it would take 18.18 seconds to raise it one foot with a one HP engine. When you throw in friction loses it won't even move.
/ Moving Felled Trees #33
I follow and agree, right up to the last sentence. (that is you would need gears that convert the 1 hp (at x rpm's) to 1ft/18sec linear speed) Drop down to a lower gear (let's say 1ft/ 30 sec) and you could overcome the frictional losses. Heck, a 1/4hp motor could lift 20000 lbs with the right transmission.
I suspect most tractors can develop a force at the drawbar that exceeds their weight given the right soil conditions/tire lugs and hooked to a chain that pulls the rear axle downward to maximize traction.
/ Moving Felled Trees #34
Friction losses in low gears can be as much as 40% so no that would not work.
Here is a useful formula I found on wiki (seems to work). load(lbs) x speed (mph)/375=HP required. So a 10,000lb load at one mph needs 26.67 HP to pull it. Cut the speed in half and you can move it with 14 hp but more likely 16 due to the extra gear-train losses cut the speed in half again and you can probably do it with not 8Hp but 10HP etc.
/ Moving Felled Trees #35
The load on the chain pulling a tree can easily reach huge numbers if pulling quickly and you run the butt end into a stump. That impact or shock load is what breaks the chain. As others have said, the machine can't steady pull hard enough to break the chain, but the chain (or a strap) can still snap easily. I've seen chain break when someone thought a "running start" would be a smart way to save time.
(it wasn't)
/ Moving Felled Trees #36
(it wasn't)
Glad to see I'm not the only one.
HYDRO TEK PRESSURE WASHER (A63569)
HYDRO TEK PRESSURE...
2019 CATERPILLAR 299D2 XHP SKID STEER (A64279)
2019 CATERPILLAR...
2009 Chevrolet 1500 Savana Van (A63116)
2009 Chevrolet...
2011 Case IH Magnum 315 Tractor (A64047)
2011 Case IH...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
Gehl RS5-19 (A62177)
