Framing Question
   / Framing Question #1
logan97
Gold Member
Blue Ridge Mnts, Va
Kubota B7800 4/wd
New Framing, I am putting a door in a corner with limited space how many inches do I need to allow for the door trim.
2 studs 1 jack 4 1/2" or 1 stud and 1 jack 3"
   / Framing Question #2
Depends on how wide your trim is
   / Framing Question #5
3" rough frame return is just enough if the opening is plumb etc...
add 1/2" (sheetrock) to the adjoining partition and that cuts it down to 2.5"...standard casing (clamb-shell, colonial etc...) is 2.25"...with 3/4" jambs and 1/4" reveal...will barely leave 1/2 between the edge of the casing and the finished wall..
   / Framing Question #6
For good construction the minimum framing would be 2 studs and 1 jack (2 jack is better). Really has nothing to do with what you need for the trim as even one stud, 1 jack will be plenty for the trim - you will also have a 3/4" door frame also going into the opening.
Been a long time since I took a course but IIANM the code requires the 2 stud/2jack.
Harry K
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
2021 ASV RT-135 Forestry Posi-Track High Flow Compact Track Loader Skid Steer (A55787)
2021 ASV RT-135...
2013 Chevrolet Traverse AWD SUV (A55758)
2013 Chevrolet...
2007 Hyundai Sonata GLS Sedan (A54815)
2007 Hyundai...
2000 GMC C7500 CRANE TRUCK (A51406)
2000 GMC C7500...
(APPROX. 250) UNUSED LANDHERO 30" TRAFFIC CONES (A54757)
(APPROX. 250)...
