New garage door opener....
   / New garage door opener.... #11
I have a 1994 vintage Craftsman 1/2 hp chain drive opener in my north barn, I can replace it with a brand new one complete with rail, two remotes, and a wireless keypad for about $150 with tax. Buying two new remotes and a wireless keypad and a wall control plus a circuit board for my current opener in an attempt to fix the intermittent operation and reprogramming required for the old one will cost at least $120. So, it makes financial sense to just buy the new one.Had 3 chamberlians(chain drive installed in 1996 on the garage and 2 pole barns,they bit the dust about 2 years back.
However, on the other end of the barn, I have a 1988 vintage Stanley 1/2 hp Lightmaker opener that has been in daily use AND NEVER NEEDED ANYTHING except light bulbs...the remotes (3) all work flawlessly.
I do wonder if the new one I am planning to buy (Chamberlain) will be anywhere near as reliable as the Stanley has been...what are your opinions on the quality of today's openers?
Had 3 Chamberlians (chain drive)installed on the garage and 2 pole barns back in 1996.They all took a dump within the last 2 years.My garage door dealer installed Hormann belt drive openers on all three and stated they are guaranteed for life against defects.I guess we will wait and see,so far so good.
   / New garage door opener.... #12
my dad put in two Chamberlain in last summer and had problems with one already.Genie screw drive are best in my opinion i have two now for 18yrs never had a problem.
   / New garage door opener.... #13
Liftmaster is the only brand I trust nowadays. Seen problems with all the other brands. If you have a jackshaft and winder spring, I like their jackshaft openers. No junk hanging over head, and a lot more reliable. You will pay more, but you get what you pay for.
For those not familiar with a jackshaft opener, I have a different brand, but it is so much quieter and faster than the over head style.
   / New garage door opener.... #14
I have two Liftmaster Jackshaft style openers. I like them, but be careful if the door catches going down, the cables will get messed up good.
   / New garage door opener.... #15
I drive openers look really great, but they have a high failure rate.
This is a decent jackshaft opener: 8500 - Elite Series
   / New garage door opener.... #16
I don't recall ever seeing, or even hearing of, a jackshaft opener before. Just another of those news things I've learned of on TBN, I guess.
   / New garage door opener.... #17
They have a cable tender device that will stop the motor if any slack is detected -- it should be standard equipment with the Liftmaster units (it was on mine).
Sadly, I know all too well the problems that happen when a door catches! I had a Wayne-Dalton iDrive unit a long time ago at our old house, and mistakenly stacked some boxes so that they just barely poked into the corner of the turn in one side track. Well, the door came down and one of the sections hung up on the boxes as it turned the corner. The iDrive unwound the whole spool of cable before I could stop the motor, leaving the door dangerously dangling overhead, jammed crooked in the tracks with rollers falling out (and two cars underneath no less). This was a 7x16 uninsulated steel door, so it was quite heavy and floppy. Somehow I got the door back up without killing myself, but it really did a number on the door and mechanisms, and it was never the same.
Eventually, the iDrive died -- the plastic parts kept breaking or cracking with age and I stopped replacing them when it got to be a weekly event. So I got a new insulated door and put in one of the Liftmaster units. The Liftmasters are slower than iDrive was, but much smoother with a simpler mechanism and far less plastic parts. Plus the mounting is more convenient (off to the side) and installation is simpler. So far I have been real happy with them. I plan to put two more of them in our new house as soon as we get the garage cleaned out and functional to get cars in there.
   / New garage door opener.... #18
The real advantage to the recent line of jackshaft openers, like the 8300 or the 8500 series is, they can accommodate a 10' high door.
Previously, you had to buy a commercial opener for anything over 8'. And they cost a lot more money.
   / New garage door opener.... #19
At my last house I installed a Chamberlain belt drive and it worked great. It worked fine for the first 10 years and may still be good. That said I found some slightly used Genie belt drive openers for my current place and they seem to operate smoother and look better built. I like how quiet the belt drive is.
   / New garage door opener.... #20
Jd My brother uses Chamberlain and in past 3 years had several where the circuit boards go bad due to lightening or power surge.
make one wonder if this is cause because same power is supplied to a Genie in second garage door about 10 feet distance. and just keeps working. buys replacement board from garage door repair company.
ken
Same here with the chamberlain. (have a jackshaft style)
The remote has been problematic since new- i think when they went to the new ones that shift the code? each time the door is opened -they have been more troublesome.
Mine just got wet and now i will have to have it replaced, hopefully the next one will work better- the remote sometimes had to be keyed repeatedly even when new...
2018 CATERPILLAR 950GC WHEEL LOADER (A52705)
2018 CATERPILLAR...
43030 (A51691)
43030 (A51691)
2014 Dodge Charger Sedan (A53424)
2014 Dodge Charger...
INGERSOLL RAND SD-100D VIBRATORY ROLLER (A52705)
INGERSOLL RAND...
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A53421)
2023 Caterpillar...
