TODAYS SEAT TIME
   / TODAYS SEAT TIME #3,251
Very nice pics. You don't see many hydraulic winches on tractors down here. I am interested in what made you decide on a hydraulic over PTO winch. I am looking for a way to put a forestry winch on my little doser. That unit you have might work for me
The winch requires only 5 gpm to operate so the tractor at ~17 gpm can handle it easily at 12 to 14 hundred RPM.
I believe the hydraulic system may be more trouble free and easier to work on than the clutch.
But this is the first skidding winch I have had so take it from there.
The wireless remote, which was on sale with the winch also pulled me in.
   / TODAYS SEAT TIME #3,252
Yesterday - started with the middle buster on, took that off, and hooked up the tiller.
Tilled the garden area (it keeps raining) with hope of soon getting some corn, purple hulled peas, and multiple types of beans planted.
Took off the tiller and put on the finish mower and gave our yard the second cutting of the season.
Took the finish mower off and put the tiller back on in hopes of using it today to get the garden a little finer after its dried a little more. I may have to get the walk behind tiller and use it as it has less of a footprint.
   / TODAYS SEAT TIME #3,253
   / TODAYS SEAT TIME #3,254
Dug a little hole with my 46 Backhoe to replace a not so anti-freeze hydrant. Turns out I ran out of arm length with the 46 at ~4.5 feet, so I had to dig the other 2 feet by hand to reach the bottom of that thing.Hydranthole.jpg
   / TODAYS SEAT TIME #3,255
Dug a little hole with my 46 Backhoe to replace a not so anti-freeze hydrant. Turns out I ran out of arm length with the 46 at ~4.5 feet, so I had to dig the other 2 feet by hand to reach the bottom of that thing.View attachment 371643
So did you figure out the problem? I have a similar problem and I was wondering if my gravel dry well at the bottom wasn't draining or something.
   / TODAYS SEAT TIME #3,256
How many Feet per minute does that thing pull and what is the rated pulling capacity? my brain seems to thinks its either slow or doesn't pull much. I looked at a used winch off a wrecker and it was more like 20 gpm and still not that fast.
A warn 9000 lb winch tops out at 45.4 feet/min @ 15 gpm on 4 layers of cable but could be as slow as 28.5 ft/m 6000 lb winch is only a few fpm faster at same capacity.
PN 30281 & 30282
PERFORMANCE DATA BY LAYER - 3/8" (9.5 mm) dia. rope
Drum Line Load * Line Speed 10 GPM Line Speed 15 GPM Drum Capacity
Layer lbf kgf kN ft/min m/min ft/min m/min ft m
1 9000 4082 40.0 19.9 6.1 28.5 8.7 25 7.6
2 7364 3340 32.8 23.8 7.3 34.1 10.4 54 16.5
3 6231 2826 27.7 27.7 8.4 39.8 12.1 88 26.8
4 5400 2449 24.0 31.7 9.7 45.4 13.8 126 38.4
   / TODAYS SEAT TIME #3,258
I got rid of some old stumps today.
I attacked the one on the right first. It would not wiggle at all when I started and I was about ready to give up on it then it started to wiggle a little when I would push on it. One thing that was hurting me was it was very wet were the stump was. If it would have been dry it would have made things a lot easier. The stump was way to big to go in the grapple. I think the one tree there was 32'' and the other was 28'' across the butt. I finally got it out. Now I need to get the one out on the left. I have it loosened up but it is really big too. It is going to rain tomorrow so it will be a mud hole there. After I get this last stump out here I am going to try to get it to drain better in that area.
   / TODAYS SEAT TIME #3,259
Duplicate post
   / TODAYS SEAT TIME #3,260
http://s278.photobucket.com/user/NHRAx1320/media/tractor/20140421_153904_zps2upbbzyj.jpg.html
http://s278.photobucket.com/user/NHRAx1320/media/tractor/20140421_153855_zpsnlgetayk.jpg.html
http://s278.photobucket.com/user/NHRAx1320/media/tractor/20140421_150601_zpsyacnbq83.jpg.html
http://s278.photobucket.com/user/NHRAx1320/media/tractor/20140421_164607_zpseeksgnzn.jpg.html
http://s278.photobucket.com/user/NHRAx1320/media/tractor/20140421_163902_zpsff6hujae.jpg.html
http://s278.photobucket.com/user/NHRAx1320/media/tractor/20140421_163858_zpsfroqfzty.jpg.html
http://s278.photobucket.com/user/NHRAx1320/media/tractor/20140421_164625_zps3qr7gi7k.jpg.html
Do you by chance have a photo of what you're lifting that stump with empty (the three point contraception)?
Sent from my iPad using TractorByNet
2001 Dorsey 48ft Flatbed T/A Trailer (A56857)
2001 Dorsey 48ft...
2012 FREIGHTLINER CASCADIA SINGLE AXLE DAY CAB (A59904)
2012 FREIGHTLINER...
2014 Glasstream 360 SCX Twin 400R Mercury's with Triple Axle Aluminum Trailer (A59231)
2014 Glasstream...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
CAT 930M (A58214)
CAT 930M (A58214)
2000 Hyster S50FT (A55973)
2000 Hyster S50FT...
