Ford 8n Windsor 351 conversion
   / Ford 8n Windsor 351 conversion #42
Your 79 F150 351W, what mods did you do?
It's been a few years back now (2006) so I'm going from memory here:
'78 block bored .060" over
Flat top hyperutectic pistons, about 9.5:1 CR
ARP chromoly rod, main, head bolts
E7TE heads ported, polished and bowl blended
Comp Xtreme4x4 cam, a little under .500" lift, short duration
Comp roller-rockers
Edelbrock performer intake
Quadrajet 4bbl carb
GM HEI ignition
Basically a low-end torque motor for rock crawling and off-roading. Pretty mild build, a little over 300hp/400lb-ft. I have another 351w on my engine stand waiting to be built for the same truck, this time stroked out to 408", 10.5:1 CR, World Windsor JR heads, balanced/blueprinted and full roller valvetrain. Hope to be well north of 400hp/500lb-ft :cool:
Great motor. And the next one is even more awesome, a 408W!
Bad news on my8N tractor project. Wife says I have to finish and dispose of 4 of my other tractors before I can start working on this one! Guess I better get crackin' on those. By spring, the 351W 8N should be back on track. Since I am gainfully employed by her and she signs the paychecks, I better start focusing! I can get all the parts lined up and here but no work 'til my old work is complete.
Oh Oh - The 351 Windsor I was picking up turned out to be a 351 Cleveland so it will not fit my brackets.
So now I am looking at a 302 Ford out of an 1984 LTD Saturday. I am supposed to be able to hear it run, always a good thing. Not quite as impressive as the 351W but still should be a sweet conversion.
I did order a ROPS with seat belt, just in case.
When I find the motor I want, I will start a new thread.
   / Ford 8n Windsor 351 conversion #45
Thanks for the pictures
   / Ford 8n Windsor 351 conversion #46
Have you done this conversion yet ? Where will you get the adapter plate kit for the 351 swap ? I hope you will post pics of the process & completed project . I am hoping to do a flathead v8 100 hp conversion before the Lord takes me home . My engine is ready for a machine shop as soon as I find a reputable shop to take it too . I got ripped good when I had my 1952 6 cyl OHV engine machined . They quoted me one price for an engine ready to be installed into my 1952 8n . But when I went to pick it up , the price was double , they loaded a bare block & everything else in boxes into my truck minus pistons , rings , gasket kit , & all the bearings needed . Plus they lost my fan blade hub assembly . So, this time I'm a little more conservative about a shop . I hope to see your completed project soon . God bless , singleken45
Actually, I switched the project up a bit. The 351 Windsor turned out to be a Cleveland and would not work forthe adapter so I went with a 302.
Here is a link to the web page for the project .
http://http://wploetz.jalbum.net/Frank-N-Ford/
and the new thread
http://www.tractorbynet.com/forums/customization/295700-1952-ford-8n-302-v8.html
   / Ford 8n Windsor 351 conversion #48
Would have been an outrageous waste of a Cleveland, anyways.
   / Ford 8n Windsor 351 conversion #49
Where do you get the adaptor plates to do the project ? Around here parts like that are not available . God bless, Ken
CATERPILLAR 303E CR EXCAVATOR (A52706)
CATERPILLAR 303E...
2016 HINO 195 16FT BOX TRUCK (A56129)
2016 HINO 195 16FT...
2019 BOBCAT T450 SKID STEER (A52706)
2019 BOBCAT T450...
JOHN DEERE TRACK TRACTOR (A54756)
JOHN DEERE TRACK...
TORO TRX20 STAND ON TRENCHER (A52707)
TORO TRX20 STAND...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
