Draw Bar on QH
   / Draw Bar on QH #1
oldballs
Elite Member
Kansas...USA
Kubota B2620 , Case 448 , Kubota B2650
Anybody got any ideas on how to stabilize a drawbar on a 3 pt Quick Hitch. Such locks are available for direct connection to the lift arms, but I'd like to leave the QH on.
Cheers,
Mike
   / Draw Bar on QH #3
   / Draw Bar on QH
Thanks you all. I've got a nice trailer hitch that I bought several years ago. But now with more implements and a recent Quick Hitch purchase, the trailer hitch pins are too narrow for the QH. Hum-m-m-m. I was thinking that a plain old draw bar might be handy to slap on the QH, without spending a bunch more money.....or....stretch those pins on the Omni CombiTrailer Hitch that I've already paid for. That Northern type gizmo would work however....that would be $70 bucks for the stabilizer and $25 for the draw bar. Maybe I'll just keep on removing the QH...argh-h-h.
Mike
   / Draw Bar on QH #5
How about a pin swap for one like this? Looks like you could gain up to about 4 inches width over standard pins.
Extra Long Lift Arm Pin Cat 1 Adjustable
Bruce
   / Draw Bar on QH #6
I converted my omni to cat 2 QH by using those same pins. Just make sure you use the bushings for your QH that have the raised ends, you should be good to go!
   / Draw Bar on QH #7
I have n Omni hitch, with the quick hitch it was too narrow. I could have got extra long pins and the the Speeco hitch pins add even more length, but it still wouldn't attach at the top without an adaptor or some grinding. I added extra long pins with Speeco pins to all my attachments to work with my quick hitch. I also ended up getting a new Omni drawbar hitch that was quick hitch compatible to bolt onto a drawbar that I wasn't using
   / Draw Bar on QH
Now, those long pins might be the answer to my wish. Will check that out. That top link hook up seems like something I can fix. Thanks, everybody.
Cheers,
Mike
2000 Ford F-650 TMA Attenuator Truck (A49461)
2000 Ford F-650...
Handlair 555 Grain Vac (A50514)
Handlair 555 Grain...
2024 Case IH Magnum 380AFS CVX Connect MFWD Tractor (A50657)
2024 Case IH...
2009 KUBOTA M7040 TRACTOR (A51406)
2009 KUBOTA M7040...
2013 Honda CR-Z (A50324)
2013 Honda CR-Z...
2018 INTERNATIONAL 4300 24FT NON CDL BOX TRUCK (A51222)
2018 INTERNATIONAL...
