Kioti LK3054 hydraulic pump rebuild
   / Kioti LK3054 hydraulic pump rebuild #1
jimlk3045
Already posted this in another forum and couldn't delete it but I figured I'd get better response here. Anyone know how to delete a post?
I've got a 1998 LK3054 that the fel was slow this morning, so i took the pump apart and it looks fine even though aluminum housing but there's a rubber seal inside that's broken. According to my local dealer there are no parts available for the pump, so they want me to replace the pump for a $5 piece of rubber. Does anyone know where i can get parts for the pump?
Thanks,
Jim
   / Kioti LK3054 hydraulic pump rebuild #2
when I purchased my '04 3054xs it was equipped with an aluminum pump and the hydraulics were ridiculously weak and slow. Dealer replaced the pump with a cast iron bodied pump under warranty; different tractor. My parts manual shows no internal pump parts available
   / Kioti LK3054 hydraulic pump rebuild #3
Patches do you have the make, model, etc on the replacement pump. I still have aluminum pump, 350 hours and no problems but only a matter of time.
Original poster, I'd pull the seal out and see if you can match up to something. Get measurements from it if you can. Is it an o-ring?
Joel
   / Kioti LK3054 hydraulic pump rebuild #4
I don't right off the top of my head, but I'll have a look around, see if I can scare something up
It's a goofy looking thing as shown below. Pump is made by Nihon Spindle and i think it's a RG2 series... found the following seals which i think will fit from Whitehouse Products LLC in the UK. I'll let you know if these are the correct seals.
Success!
For anyone else not interested in taking the kioti shaft, the seal kit is available from whitehouse products llc in the uk.
Part number: 5N2/39801NISA01 SEAL KIT TO SUIT PAA66RD268
27ft x 24ft Metal Building (A51573)
27ft x 24ft Metal...
2006 FORD F-150XL TRITON EXT CAB TRUCK (A51243)
2006 FORD F-150XL...
2014 International WorkStar 7400 Truck with Knuckle Boom Crane, VIN # 1HTWGAAR2EH765294 (A51573)
2014 International...
Under Body Toolbox (A51573)
Under Body Toolbox...
2019 Kubota RTV-X1140 4x4 Utility Cart (A51691)
2019 Kubota...
2023 John Deere 6155M MFWD Tractor (A53342)
2023 John Deere...
