Any love for the DR 3 point hitch string trimmer attachment?
   / Any love for the DR 3 point hitch string trimmer attachment? #11
That thing looks fantastic. I really can't do string trimmers anymore because of some medical issues, I have to get my kid to do it or someone else. And I have a push type with two wheels.
I might look at getting this thing and selling off the other string trimmer.
Something new to research, anyone have any experience with anyone else that makes something like this?
As far as I Know they are the only ones. It would fit your tractor pretty well.
   / Any love for the DR 3 point hitch string trimmer attachment? #12
Another one:
Weed Chopper
Or put your walk-behind trimmer on a side boom.
http://www.mytractorforum.com/showthread.php?t=1183
Bruce
   / Any love for the DR 3 point hitch string trimmer attachment? #13
We have one. It is sized well for our B7500, it doesn't work as well on our L3830 as the L isnt as maneuverable especially in corners.
I generally put the B7500 in the 1000 RPM pto range, run the throttle to ~1000 engine RPM (which gives ~540PTO RPM) and roll along the fenceline.
It really needs the full 540 PTO RPM to cut well, but I dont like having the engine screaming along with little to no load.
This summer I may re-install the 3 point hitch on our BX2660 (it came off in the first week and hasn't been back on since) and see how that handles the DR and the mower deck at the same time.
Aaron Z
   / Any love for the DR 3 point hitch string trimmer attachment? #14
Aaron Z
That sounds like a good idea, when you are along the fence, trees, whatever you could turn on the back pto and get those edges. Then when in the middle of the yard you just run the one for the belly mower.
I think what I am going to do is try to adapt my walk behind trimmer to be pulled by the tractor. I can't push it anymore so it really gets little use. I think I can make something with some brackets and a long spring loaded arm, use an old trampoline springs and I think I can get the same results....we will see.
   / Any love for the DR 3 point hitch string trimmer attachment? #15
What about a way to mount it on your bucket offset to the side where you could see it?
   / Any love for the DR 3 point hitch string trimmer attachment? #16
Even better idea.....turning around to look behind gets me too.....soviet metal took a toll on me not long ago.....I am not real keen on drilling holes in the bucket, but that rachet rake setup seems to work darn well....perhaps some kind of attachment like that.
I think you have given me a new project to get started on......just as soon as I get the bearings back in the 650's mower deck I am going to start on that.
Seems this tractor stuff has taken me away from playing with my 63 VW bug.
   / Any love for the DR 3 point hitch string trimmer attachment? #17
For just a little more you could get the one designed to pull behind an atv and it is off settable. I am looking into that one even though I am also looking to purchase a new tractor. Just a thought.
   / Any love for the DR 3 point hitch string trimmer attachment? #18
DR Power 3-Point Hitch Trimmer Mower: Brush Cutter & Fence Line Mower
i am intrigued and tempted to buy one, the reviews bother me. anyone here using one? your thoughts?
I have recently bought one, it takes a little getting used too, you need to read carefully the manual and once your acclimated to using it you become more proficient. I found the spline on tractor to PTO connection was a little more work than needed, but once the spline was clear on the PTO shaft supplied, it was all fine. I made a video for it, explaining somethings that I wish I could have seen prior to purchase, maybe it will be helpful to others.
Again I would have liked to see the connection points, etc. ahead of my purchase. Not knocking it all, it does exactly what I want, I just would like to have seen more intuitive information on installation.
Here is the link: DR 3pt Trimmer Review - YouTube
Good luck, Todd
   / Any love for the DR 3 point hitch string trimmer attachment? #19
A friend works for a DR dealer. He already got a couple of busted ones. I guess they just replace them for the customer. Not sure what busted. Maybe the spindle if memory serves me. I don't think he has used them to report what he thinks of them.
   / Any love for the DR 3 point hitch string trimmer attachment? #20
I've not been impressed with much of what DR sells.
(INOP) 2005 JCB 506C TELESCOPIC FORKLIFT (A50459)
(INOP) 2005 JCB...
Mitsubishi FG35 Forklift - 8,000lb Lift Capacity, LP Gas (A52128)
Mitsubishi FG35...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 84"...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52141)
2019 INTERNATIONAL...
2018 Nissan Versa Sedan (A50324)
2018 Nissan Versa...
2016 HINO 268 26FT BOX TRUCK (A52141)
2016 HINO 268 26FT...
