7308 loader won't hold curl
   / 7308 loader won't hold curl #1
larpai
Merritt Island
New Holland TC33D
I purchased a used TC33D with loader about a month ago. After about 10 hrs. use, the bucket will now slowly uncurl on its own. Lifts fine, curls fine and dumps fine, just won't hold the curl. I constantly have to keep hitting the lever to keep the load from dumping on its own.
Any advice is much appreciated.
Thanks Larry
   / 7308 loader won't hold curl #2
the directional control valve is allowing flow back to tank.
Something inside is amiss.
Does the valve provide regeneration function?
I understand small engines and cars but hydraulics is new to me. What is "regeneration function"??
   / 7308 loader won't hold curl #4
Regeneration directs the fluid flow out of the compressing side of the hydraulic piston into the extending side of the same piston.
This has the effect of Speeding up the extending function. It is often used to speed up the dump cycle of a bucket. Exactly your situation.
Still, The DCV is at fault. It will need to come apart for inspection. Might just need cleaning.....or a spring or something
   / 7308 loader won't hold curl #5
Problem could also be a leaking bucket cylinder piston seal or both cyl piston seals.
   / 7308 loader won't hold curl #6
It could be the cylinder bypassing but my money is on the control valve leaking by. Replace or rebuilt it and your problem should go away
   / 7308 loader won't hold curl #7
I've seen more cyl piston packings fail than control valves fail. If it was my loader I'd check the cylinders for internal leakage.
   / 7308 loader won't hold curl #8
I agree. Way more cylinder packings than control valves. In my over 25 years working on CUT's I can count on one hand the number of controls valves I've seen fail and have long since lost count of cylinders I've repacked.
Brian
   / 7308 loader won't hold curl #9
If the cylinder packings are at fault, there will be hydraulic fluid dripping on the ground where they are leaking. The rod displacement needs to go somewhere. If it can't get back to tank, the bucket is not going to droop.
If there is no external leakage, the leakage must be internal, and MUST return to tank to allow bucket droop. Fluid just passing the cylinder piston won't do it.
Very easy diagnosis.
It is possible that the spool valve leaks between bucket and lift arm cylinders, with the bucket drooping as the arms lift. But the fix is the same. The DCV needs attention.
   / 7308 loader won't hold curl #10
One or both of the cylinders is leaking around the piston seals. As oil leaks past the seals it allows the rods to extend out further allowing more room for more oil in the butt end of the cylinder. I would bet he can raise his loader off the ground, curl bucket back, unplugged his hoses from the tractor and it will still uncurl.
Very easy diagnosis...........
2020 Nissan Rogue SUV (A51694)
2020 Nissan Rogue...
2011 Nissan Rogue SUV (A53424)
2011 Nissan Rogue...
2006 John Deere HPX Gator 4x4 Utility Cart (A50324)
2006 John Deere...
2023 ALLMAND MAXI-POWER 15XR GENERATOR (A53843)
2023 ALLMAND...
ROLOFF 500 BBL FRAC TANK (A53843)
ROLOFF 500 BBL...
