7308 loader won't hold curl
   / 7308 loader won't hold curl
Brian Which side is the base port?
   / 7308 loader won't hold curl #22
The base port is the piston side of the cylinder vs. the rod port which is the side that obviously feeds the rod side of the cylinder. The base port will usually be the top port of the bucket cylinder.
Brian
   / 7308 loader won't hold curl #23
Cylinders have a base or butt end and a rod end. Your base end is toward the rear of tractor.
I tried Brian's suggestion and disconnected the top connections on the cylinder with the bucket blocked in the full curled position. Oil flowed from the right cylinder so I had that cylinder rebuilt. The bucket now stays curled even fully loaded.
Thanks for all the helpful suggestions.
Larry
   / 7308 loader won't hold curl #26
Glad to hear you got it taken care of.
Brian
1067 (A53342)
1067 (A53342)
2019 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A52377)
2019 HarbinGer V3...
2014 Peterbilt National Crane Series 900A 26 Ton Tri-axle Crane Truck (A52377)
2014 Peterbilt...
2004 Freightliner FL112 Cab & Chassis (A47384)
2004 Freightliner...
2018 MACK CHU613 DAYCAB (INOPERABLE) (A53843)
2018 MACK CHU613...
2016 CATERPILLAR 249D SKID STEER (A52705)
2016 CATERPILLAR...
