cant find rototiller make?
   / cant find rototiller make? #1
realdeal814
emlenton,pa
new holland 3040
   / cant find rototiller make? #3
The phone number comes up as Don Sloan Painting when you google it.
If you post a pic of the tiller we might be able to ID it. ??
Most bearings are generic and easy to find by their stamped number or dimensions.
I buy a lot of bearings for my business from- Bailey International | Mobile Hydraulic Solutions
Thanks deerseeker. Stimw i couldn't even find that so you have done better than i could. the problem is the bearing closest to the gear box on the pinion shaft was totally destroyed and i wasn't sure if it was the same as the other bearing. i would like to get a diagram of the inside so i could see what all shims/spacers i would need. Thanks for the help Stimw
   / cant find rototiller make? #5
Pictures! Pictures! We love pictures.
Does the tiller look like this? If it does then it is a Caroni and Agri Supply carries some things for them.
well it kinda does. the gear box looks a little different but what do i know. heres a picture maybe someone knowsIMG_20140426_221922_616.jpg also i believe i found the right bearing. i was able to piece it together and it looks like 30207a. trying to see if timken makes one but haven't found it yet.
2012 Infiniti QX56 SUV (A55853)
2012 Infiniti QX56...
MARATHON 76KW GENERATOR (A55745)
MARATHON 76KW...
TANK MANIFOLD (A58214)
16FT box truck (A53422)
16FT box truck...
200lb Anvil (A55853)
2019 Doosan LCV6W Towable LED Light Tower (A54811)
2019 Doosan LCV6W...
