Plastic Fuel tank repair suggestion (in this case, its a lawn tractor)
   / Plastic Fuel tank repair suggestion (in this case, its a lawn tractor) #1
elbow42
Big Sandy, TX
Jinma 280
The fuel tank on my Scotts/Murray lawn tractor developed a hair line crack around one of the four mounting posts at the point where the post meets the tank. Shopping around I quickly found out how high priced they are. On the internet, the ones I saw on ebay, amazon, or parts suppliers ranged from $59.99 to $135.00 plus shipping that was typically $13 and up. So, of course I started trying to figure out how I might repair it instead. "Nothing to lose" I thought. Not only am I cheap, I'm sentimental. My old Scotts and I go back 17 years, mowing several acres of very rough and rocky terrain. Together we have destroyed a lot of blades and other parts as well. :)
So, I began trying to find something made specifically for a repair, and then it occurred to me that maybe the best material for the job would be the same plastic as the tank is made of. The tank has a "guard" around the filler cap, for what reason I don't know. On my tractor, at least, there is nothing nearby to guard the cap or filler hole from. It is easy to cut off a short, narrow strip from the guard with tin snips. Next drain, wash out and dry the tank. Then clean the area around the crack thoroughly with solvent or whatever works for you. While gripping the scrap with forceps, pliers or whatever, light the plastic with a match. It will burn and melt very slowly. Following closely along the crack, drip enough melting plastic onto the tank to cover the crack and a little surrounding area. Provided that the plastic stays hot enough, it melts slightly into the tank itself, so you need to be close. Don't linger too long in one spot or it might melt through the tank. This worked well for a crack. I don't know about fixing a hole.
Of course I don't know if this will work for all tanks. I'm sure it depends on what type plastic it is. Some probably behave differently than others. Mine is a white translucent plastic and from what I've seen a lot of them are. But, so far it has worked on mine. Only time will tell.
   / Plastic Fuel tank repair suggestion (in this case, its a lawn tractor) #2
Try these if it doesn't. Check out the video on the plastic boat repair product, pretty durable...
WEST SYSTEM | Repair Kits
   / Plastic Fuel tank repair suggestion (in this case, its a lawn tractor) #3
I second the West System. Go to West Marine and get a tube of 6-10 if anything will fix it 6-10 will. Preparation is key.
   / Plastic Fuel tank repair suggestion (in this case, its a lawn tractor) #4
Harbor freight has a plastic repair kit using a hot gun with air running through it.
They also have different material for the different plastics.
A friend of mine fixed his plastic radiator with the heat gun, and parts of the radiator
Plastic Welding Kit
Plastic Welder & Welding Kit
50 Piece Plastic Welding Rods
Wash it out and clean the crack and match up the filler with whatever.
   / Plastic Fuel tank repair suggestion (in this case, its a lawn tractor) #5
I have had good results with a hot glue gun and the sticks as basically they are a PVC blend and fuse with the tank material.
Naturally thorough cleaning is needed.
Thanks. Nice suggestions.
   / Plastic Fuel tank repair suggestion (in this case, its a lawn tractor) #7
The hot air gun process is the best in my opinion. In my pipe fitter days I did a little of it, never got real proficient though. I repaired my MH draoin tanks working in the overhead position. A real learning curve believe me but I got it done. Matching material is important. Heat control is harder than welding steel to keep the puddle from falling through. Use just enough heat to fuse well and keep moving off to let it solidify. Go slow not fast. For cracks, drill a hole at each end for stress relief. Practice on some scrap stuff first. When you get good at it the beads look similar to welding steel.
Ron
   / Plastic Fuel tank repair suggestion (in this case, its a lawn tractor) #8
There are some new adhesives for repairing PE: https://www.tapplastics.com/product/repair_products/plastic_adhesives/tap_poly_weld_adhesive/435
I've use the plastic welding hot air guns and it's tricky to get PE to bond well even to itself. I try to have another piece handy to press on the molten plastic to smooth it out and help it bond.
One tip for repairing with a glue gun is to reinforce the repair with some cloth. The hot glue never gets very hard but making a composite with cloth will add lots of strength.
   / Plastic Fuel tank repair suggestion (in this case, its a lawn tractor) #9
I repaired a plastic tank using a soldering gun and nylon cable ties as a filler material. I also have the HF plastic welder but did not use it for this repair. The repair has lasted almost 5 years without leaking.
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2016 Chevrolet Tahoe SUV (A51694)
2016 Chevrolet...
PALLET OF ARMSTRONG CEILING TILES (A51248)
PALLET OF...
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
2019 John Deere HPX615E Gator 4x4 Utility Cart (A51691)
2019 John Deere...
