Plastic Fuel tank repair suggestion (in this case, its a lawn tractor)
   / Plastic Fuel tank repair suggestion (in this case, its a lawn tractor)
Thanks for all of the great suggestions. So far my repair job is holding. If it fails, there's lots of good info here.
   / Plastic Fuel tank repair suggestion (in this case, its a lawn tractor) #12
There are some new adhesives for repairing PE: https://www.tapplastics.com/product/repair_products/plastic_adhesives/tap_poly_weld_adhesive/435
I've use the plastic welding hot air guns and it's tricky to get PE to bond well even to itself. I try to have another piece handy to press on the molten plastic to smooth it out and help it bond.
One tip for repairing with a glue gun is to reinforce the repair with some cloth. The hot glue never gets very hard but making a composite with cloth will add lots of strength.
A little strip of window screen (metal or polyester) makes a fine lay-up material with hot glue. Also works well with 2 part epoxy on rigid plastics.
(2) UNUSED 3500# IDLER AXLES (A51247)
(2) UNUSED 3500#...
2012 CHEVROLET SILVERADO SINGLE CAB TRUCK (A51406)
2012 CHEVROLET...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
2025 Safety Basket Forklift Attachment (A51691)
2025 Safety Basket...
2004 BMW Sedan (A51694)
2004 BMW Sedan...
2017 Nissan Altima (A51694)
2017 Nissan Altima...
