Hi, I went back to the shop today. The mechanic tried to start the tiller while I was there. No spark.
He took the carburetor bowl off, cleaned the gunk out and gas flowed through the line and when the carburetor bowl was lifted, gas stopped flowing.
After several cranks, he tested the spark with an in-line spark indicator. After more fiddling and testing, there was still no spark. He tested the condenser and said that it was holding the correct amount of charge properly. He said he had tested the spark plug wire itself and it proved good. He checked the points again, cranked and got no spark. He advanced the spark somewhat as a test and still got no spark. His buddy held a screw driver in the spark plug cap while he cranked - no spark. He said that the push rod was actuating the points properly, the fly wheel tab was not damaged.
There was no difference with the case to the points on or off. The kill switch button did not appear to be malfunctioning.
Earlier he had replaced the rope pull mechanism, but says that the tiller had started at that time, although it picked up the stalling habit sometime in there.
The guy is stumped. I need help to get this going.
Does anyone know if there is a web site for Troy Bilt Kohler motored tiller owners that I could check with to see if there is any new thoughts there? I'd appreciate it. Thanks, Dan DeWitt
