sixdogs
Super Star Member
- Joined
- Dec 8, 2007
- Messages
- 13,820
- Location
- Ohio
- Tractor
- Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have to drill some holes and would like to use my JD790 with industrial tires and my typical TSC style post hole digger and auger. I'm not sure if the 3PT arms will lift enough for the tip of the auger to clear the ground during transport. Does anyone know or does anyone use a TSC type PHD with auger on a JD790? Does it clear the ground when you move from one hole location to another?
The 790 does not have any adjustment holes on the rear arms so I can raise it higher so it will either work or not work. Plus the industrial tires put it a little lower to the ground.
Thanks in advance.
Thanks in advance.
