Will a post hole digger clear ground OK on my JD 790 with industrial tires?
   / Will a post hole digger clear ground OK on my JD 790 with industrial tires? #1
sixdogs
Super Star Member
Ohio
Kubota M7040, Kubota MX5100, Deere 790 TLB, Farmall Super C
I have to drill some holes and would like to use my JD790 with industrial tires and my typical TSC style post hole digger and auger. I'm not sure if the 3PT arms will lift enough for the tip of the auger to clear the ground during transport. Does anyone know or does anyone use a TSC type PHD with auger on a JD790? Does it clear the ground when you move from one hole location to another?
The 790 does not have any adjustment holes on the rear arms so I can raise it higher so it will either work or not work. Plus the industrial tires put it a little lower to the ground.
Thanks in advance.
   / Will a post hole digger clear ground OK on my JD 790 with industrial tires? #2
Thanks in advance.
Try using a piece of rope to tie the auger up during travel.
As long as it clears when you use it it's ok.
When I use my PHD on my B7610 the auger BARELY clears the ground.
But I figure as long as it clears by an inch when I use it that's ok. Works great on my M4700 :)
   / Will a post hole digger clear ground OK on my JD 790 with industrial tires? #3
My 1070 predates the 790 and the TSC digger easily clears the deck in transport. The Top-link length and hole position also controls the lift height.
   / Will a post hole digger clear ground OK on my JD 790 with industrial tires? #4
I have borrowed 790 that my neighbor has. My PHD was busted and somebody had hit my fence.
Had plenty of clearance on his and I don't recall any trouble even getting it off the trailer it was on with the PHD attached.
He uses it all the time and doesn't appear to have any trouble, he built about 2 miles of fence with it that I have seen.
   / Will a post hole digger clear ground OK on my JD 790 with industrial tires? #5
Here is what mine looks like in the middle hole of the third arm, I gain a little when it's in the bottom hole. I think you'll be fine. This is a rhino brand. You have to be careful backing off the gooseneck trailer with it, it drags the dirt a little between the flip over ramps. LUTT
Wow, thanks everyone and it sure looks like it will work. Thanks for the photo, lutt.
   / Will a post hole digger clear ground OK on my JD 790 with industrial tires? #7
I have a Leinbach PHD on my 4115, and it clears the ground fine. Your 790 is even taller, so you will not have any problems.
   / Will a post hole digger clear ground OK on my JD 790 with industrial tires? #8
I have a Leinbach PHD that I use on my 790, but it's been a year or more since I last actually had it attached to the tractor. As best as I can remember, it seems like mine cleared the ground about the same as LUTT's did, in his photo. I tried adjusting it every way possible to get the most clearance, and that was the best it would do.
   / Will a post hole digger clear ground OK on my JD 790 with industrial tires? #9
Your welcome Six dogs, wish I was home to take measurements, I still have about ten days or so being out here at work. That is with a twelve inch auger on in that pic, I also have a nine, but never used it. LUTT
   / Will a post hole digger clear ground OK on my JD 790 with industrial tires? #10
I don't know if a 790 has the three holes for the third arm, my 4200 does, I gain a little in the bottom hole, like you I've tried everything I could to gain some clearance. Really don't take much, just got to watch backing up! LUTT
2018 DandA 220V Hydraulic Breaker Excavator Attachment (A51691)
2018 DandA 220V...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2012 VOLVO VNL TANDEM AXLE SLEEPER (A52576)
2012 VOLVO VNL...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2018 INTERNATIONAL 4300 26FT NON CDL BOX TRUCK (A52576)
2018 INTERNATIONAL...
2025 New/Unused LandHonor Heavy Duty Plate Compactor (A51573)
2025 New/Unused...
