JC-jetro
Elite Member
I'll have to look at the manual and see what panels I can remove easily to get access to do such spraying. As mentioned in original post, I've already ran 50/50 diesel/tractor fluid through it. It that was a mistake, the damage is done. Thanks, Dean
There is no panel to take out. You can take out the lift cover to have access below. I do not recommend it at all as it is a lot of work for not much gain. As you withdraw the screen leave you a good size hole to send a nozzle in and sweep up the bottom of diffy. If you use a shop vac you obviously dirty it up along with the inside of your shop vac hose. I used a piece of garden hose Mounted on a stiff 1 gallon clear bottle (apple juice), poke a hole on the side and inserted shop vac hose in the bottle to make a "vacuum suction cup" and sucked it all up in to a container without getting shop vac dirty. with garden hose you can cover a lot of area around the bottom of diffy.
JC,
