New Holland 345D miscommunication
   / New Holland 345D miscommunication #1
brain55
Brentwood, CA
So a customer calls me to look at "hydraulic" leak on his tractor. I start it up and lift the 3-pt, the tube between the hydraulic pump and flow control is leaking. So I let the foreman that called me know what was going on and that the front diff was leaking at the pivot and we decide that could be fixed later. So I pull the top cover and discover the feedback arm for the draft control is broken, which meant I needed to order parts. The next morning I got a call from the owner "Hey why is the seat off of this machine?, the front axle is leaking, that's what I wanted fixed". I explained to him what happened and he was fine, he even called it a hydraulic leak.
I got it all finished today. I just want to say New Holland is exceptionally proud of those front axle pivot bushings, sleeves and thrust washers well over $1200. It was getting late so I didn't get any pictures of that part of the repair unfortunately.
Here's the broken feedback arm.
You can see how worn out the 3-pt piston o-ring is too
Brian
   / New Holland 345D miscommunication #2
If those trunnion bushings got a little grease every now & then, they wouldn't have worn, and that silly little o-ring would have kept the oil in the axle. Another instance where grease is cheaper than parts.
I agree. My greasing it at oil changes isn't often enough I'm afraid. In New Holland's defense this machine is 20 years old and does have 2300+ hours on it.
Brian
40' CONTAINER (A51244)
New Holland B95 Backhoe (A50490)
New Holland B95...
2022 Chevrolet Tahoe FL SUV (A51694)
2022 Chevrolet...
2018 Dodge Charger Passenger Car (A51694)
2018 Dodge Charger...
2017 Ram 5500 Valve Placer Bucket Truck with Versalift STP36NE - 41FT Working Height, Low Miles (A52748)
2017 Ram 5500...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
