Snake Medicine
   / Snake Medicine #1
nikdfish
Person Co. NC
John Deere 3038E & 1025R FILB
With the warmer weather, we've started seeing some of our less favorite woods denizens moving around, ticks & snakes. Last night I made up a batch of snake medicine (ticks get chemical warfare...).
50 rounds of Speer .38 caliber shot capsules filled with #8 or #9 shot over 3.8 grains of Bullseye. The #8 shot came from some recycled corroded 12 gauge loads found in an outbuilding we cleaned out recently.
Nick
   / Snake Medicine #4
all snakes are beneficial...even the venomous ones...better to be judicious and re-locate the dangerous ones than eliminate...
There is a balance in nature that humans are sometimes just incapable of comprehending...
   / Snake Medicine #5
Yep there is a balance - they can fertilize the woods when they decay. If it is poisonous it dies. See Im helping the trees and plants grow and it beats having one of my kids, pets, wife,etc getting bit
   / Snake Medicine #6
I got a little recipe to keep them away: :Dground chillies (coffee grinder) :Dmixed in canola oil spreded over the familiar resting spots, it works!:
   / Snake Medicine #7
What kind of distance do you get with those and what is the blue thing called?
   / Snake Medicine #8
Great recipe. You just need to add 12 ga buckshot to make it perfect.
   / Snake Medicine
The pattern spreads about an inch per foot of distance so anything over 10' or so would start getting iffy. The blue is the visible portion of a Speer shot capsule. They are two part: the capule is a tube with one end open that you fill with shot (roughly 109 grains worth) and is prescored on the closed end to help with consistant fracturing when fired; the cap that you snap in to seal the tube also acts as the wad for the load.
The capsule assembly extends a bit more then halfway down the brass when seated with maybe a third of the shot column visible. The .38 caliber variety comes 50 to the box, .44 & .45 come 25 to the box. The .38 box I bought from Midway was a bit less than $8.
Nick
   / Snake Medicine #10
I am 100s of miles south of you by the NY border and I have never seen any snake apart from those harmless/beneficial garter garden variety, you should start working on a recipe for those black flies and other flying nuisances up there in Lac St-Jean Mike lol
2004 John Deere 9320 Articulating Tractor (A50860)
2004 John Deere...
2012 Chevrolet Tahoe LS SUV (A48082)
2012 Chevrolet...
2022 J&M 1151-22S Classic Grain Storm Grain Cart (A50657)
2022 J&M 1151-22S...
Tubing A500 Grade C 6in. SQ X 1/4in. X 28ft. (A50860)
Tubing A500 Grade...
1240 (A50490)
1240 (A50490)
2007 Case IH 8010 4WD Combine (A50657)
2007 Case IH 8010...
