1986 kubota L345dt no start
   / 1986 kubota L345dt no start #1
chickadee
moultonbrough n.h.
kubota L345dt
replaced starter both red lights on dash work!! glow plugs work!! can start by jumping between small starter wire an large 12v wire?
   / 1986 kubota L345dt no start #4
Welcome to TractorByNet!
We moved your thread to the Kubota Owning & Operating forum. :)
   / 1986 kubota L345dt no start #5
Does it have any "neutral" switches, say on the pto, rocker "go" pedal, etc. That's what it sounds like to me if every other system is "go".
The newer ones have two on the seat switch as well.
f.
   / 1986 kubota L345dt no start #6
Probable cause's....
neutral safety switch,
ignition switch,
make sure pto is not engaged,
fuseable link to the starter blown.
   / 1986 kubota L345dt no start #7
There is a S-shaped exposed 30-amp fuse mounted on the firewall that gets corroded terminals and no longer passes enough current to operate the solenoid. Powering the solenoid by jumping it bypasses the corroded fuse. For my L3445DT I bought an in-line 30a replacement fuse and wired it in - problem solved.
2013 Hyundai Sonata Hybrid Sedan (A50324)
2013 Hyundai...
2006 JLG SKY TRAK L10 10054 FORKLIFT (A50322)
2006 JLG SKY TRAK...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
UNUSED AGT KRW23 WHEEL LOADER (A51243)
UNUSED AGT KRW23...
2007 Freightliner School Bus (RUNS) (TITLE) (A50774)
2007 Freightliner...
2000 Ditch Witch 3700DD Ride-On Trencher (A51568)
2000 Ditch Witch...
