Ford 445 - hard to start
   / Ford 445 - hard to start #1
mjmcdonald21
White House, TN
Ford 445
I've recently bought a 78-83(?) Ford 445 Industrial tractor with loader. Regular maintenance was not a priority for the previous owner so I've slowly been catching everything up. (new fluids, filters, etc)
The tractor won't start without a small shot of ether. After warming to operating temperature it still won't start without ether. It will let out a small amount of white smoke after starting but the smoke stops quickly. The glow plug does not work on this tractor. Once running, it's got plenty of power and I would say that it runs great.
I'd like to fix whatever is causing it to depend upon ether, if possible. Any help would be greatly appreciated.
TractorData.com Ford 445 industrial tractor information
   / Ford 445 - hard to start #2
if it's already ether addicted.. then it is likely low on compression. that is almost always rings and cyl walls. sometimes has valves/head involvement.
   / Ford 445 - hard to start #3
Agree. Compression test is in order. Test injectors while they are out for the CT.
2014 INTERNATIONAL DURASTAR 4400 SERVICE TRUCK (A51406)
2014 INTERNATIONAL...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A53426)
2016 Chevrolet Tahoe SUV (A52377)
2016 Chevrolet...
2015 Ford E-350 Cutaway Van (A52377)
2015 Ford E-350...
ECHO CS4010 CHAIN SAW (A51248)
ECHO CS4010 CHAIN...
HLA SE50AO600G LOT NUMBER 31 (A53084)
HLA SE50AO600G LOT...
