Can I get suggestions for weed killer?
   / Can I get suggestions for weed killer? #1
coffeeman
Want to kill grass , weeds, along driveway, in blacktop, along fence lines etc. Also would want to kill grass etc in mulch. I'm worried for shrubs & close by plants like flowers, Do have couple feet and more between plants.
Cheers.....Coffeeman
   / Can I get suggestions for weed killer? #2
Glyphosate (generic Roundup) will do the trick. Prices have gone up in the last year or so, but you can buy 2.5 gallons of 41% glyphosate for less than $60. A 1.5% mix requires 2.67 ounces per gallon of water and will knock out your grass and weeds.
You can buy a pump sprayer with a plastic shield at the end of the nozzle to minimize drift while spraying. Hold the nozzle close to the target and don't spray on a windy day.
Steve
   / Can I get suggestions for weed killer? #3
I'll second gly. It can take a couple of weeks before you start to see the burn down, but it's the cheapest way to go that I know of.
   / Can I get suggestions for weed killer? #4
Tractor Supply has pretty decent prices on glyphosate.
   / Can I get suggestions for weed killer? #5
I use vinegar with a few drops of detergent in it.
   / Can I get suggestions for weed killer? #7
Use glyphosate if you want. Personally I wouldn't touch that stuff. Ever heard the term "endocrine disruptor"?
   / Can I get suggestions for weed killer? #8
Glyphosate (Roundup) is probably your best choice. It will only kill green plants that it touches. It has no residual, which means it does not last in the soil. In fact, it is 100% neutralized the instant it touches soil.
You must be careful that you don't get it on any plants that you don't want to kill, but, just keep your nozzle low, don't spray on a windy day, and spray with large droplet size, to avoid drift.
   / Can I get suggestions for weed killer? #9
100% neutralized, eh? The instant it touches the soil, huh? A quick Google search doesn't seem to agree with your info, hope you're not just spreading whatever Monsanto chooses to print in its brochures. I don't mean any offense, but for a while they said that stuff was "non-toxic" and had salesmen drinking it.
   / Can I get suggestions for weed killer? #10
Maybe I should say "The herbicidal effect of glyphosate is 100% neutralized the instant it touches soil"
I do know however that glyphosate has changed farming tremendously, and has reduced the amount of more toxic herbicide use. And glyphosate has reduced the cost of production of crops which also helps keep consumer costs down.
I also know that the LD50 of table salt is much lower (which means it's more toxic) than glyphosate.
Informational Lot - Shipping (A53473)
Informational Lot...
2011 FORD F750 XL SUPER DUTY DUMP TRUCK (A51406)
2011 FORD F750 XL...
UNUSED Heavy Duty Ratchet Strap Set (A53117)
UNUSED Heavy Duty...
CAT 938G Wheel Loader (A47477)
CAT 938G Wheel...
2012 Honda Accord Sedan (A53424)
2012 Honda Accord...
2012 Ford F-350 4x4 Knapheide Utility Flatbed Truck (A51692)
2012 Ford F-350...
