Mahindra transaxle oil
   / Mahindra transaxle oil #1
terraformer
N.E. Mo
Mahindra 3510, Bolens G192/Iseki 1910
I was checking the fluids on my Mahindra 3510. And realized that the oil the rear dipstick was low. Perhaps I have some seepage but more importantly what oil should I put into it. Gear oil, hydraulic oil.
   / Mahindra transaxle oil #2
Most tractors of today have multifunctional usage of the lube; wet brakes, tranny, diff, hydraulics, etc. TSC Premium Trans Hydraulic fluid meets the most stringent requirements out there as best I can tell. Read the applications on the back and they are current and numerous. Since JD is a popular brand, I find that J20C is the spec for the latest requirements for multi-use lube so I ensure that spec is on any fluid I purchase for my Branson.
Mark
Thanks
   / Mahindra transaxle oil #4
s
In my 2002 - mahindra 4110 its trans/hydraulic fluid . I also have been using Tractor Supply premium trans/hydra fluids
Hey Buck
I checked the fluid again and it seemed fine. I was on a very slight slope....oops.
Turns out the fluid under the tractor was fuel. The fuel filter/shut off sediment trap was leaking. It had been repaired in the past as there was some jb weld on the filter housing at the flange of the plastic part.
I put on a Mercedes diesel pre filter on it and removed the unit. The leaks quit. For a permanent fix I am going to put on a VW fuel filter the same as on my old vw diesel car. It is a disposable can with two barbs for the fuel line and a removable bolt to bleed the system. Cost is less than 20 dollars. I spent more on the jumbo bottle of oil.
2008 Ford E-250 Cargo Van (A50323)
2008 Ford E-250...
2007 POWERSCREEN CHIEFTAIN 2100X INCLINED SCREEN (A54607)
2007 POWERSCREEN...
2012 Chevrolet Silverado 2500 HD Enclosed Service Truck (A52377)
2012 Chevrolet...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A53422)
2013 Ford F-150...
STORAGE FEES (A54607)
2012 CATERPILLAR 304E CR EXCAVATOR (A51242)
2012 CATERPILLAR...
