John Deere Model 71 drive chain issues
   / John Deere Model 71 drive chain issues #1
mattradintz
Glenwood City, WI
Bobcat CT230
Anyone know where to look first if my chain keeps jumping off on one of my row units on the tension idler assembly. It seemed to work better before I tore it apart and painted it....
Thanks!
   / John Deere Model 71 drive chain issues #2
Check for misalignment.
How do I check for misalignment? I order and installed new chain, sprockets, idler cam assembly, thrust washer... basicall everything inside the drive unit and it is still skipping off the 2 small 7 tooth idler sprockets. Getting a little frustrated.
Thanks in advance...
   / John Deere Model 71 drive chain issues #4
Looking at the picture, if you put a straight edge on the driven gear (big one on right side of pic), the chain and drive gear should be in line. The planter in the picture is a 70 Flexi, and doesn't use an idler. In your 71, all the gears have to line up. Another way to check would be to measure from the back of the drive housing to make sure all the gears are at the same distance. HTH. Mark
2011 Ford Crown Victoria Sedan (A48082)
2011 Ford Crown...
2014 MACK GU (GRANITE) (A50854)
2014 MACK GU...
Redirective Crash Cushion Guardrail (A48081)
Redirective Crash...
ALL TITLED ITEMS HAVE A $35 TITLE FEE!!! (A50774)
ALL TITLED ITEMS...
2017 Bad Boy Outlaw XP 61in Zero Turn Mower (A48082)
2017 Bad Boy...
Yamaha Rhino 660 UTV (A50860)
Yamaha Rhino 660...
