trailer ball capacity / shank size
   / trailer ball capacity / shank size #12
The original Convert a balls are what I use most. I have two mounts for different drops. Both mount and ball rated for 10,000#. Also have some equalizer hitches and pintle hitches on solid square mounts. It was the odd ones laying around I was concerned about.
Dan
That's what I use is the stainless convert-a-ball along with their dampened hitch--all rated at 10,000 GVWR, the max tow of my F150. I really like the convert-a-ball system and use their storage box to carry 1-7/8", 2" and 2-5/16" balls.
   / trailer ball capacity / shank size #13
Good idea to bring up this issue.
My heavy duty combo is a solid bar with three balls welded to it. Rated at 10 or 12K IIRC. I use that for my dump trailer, besides the my gooseneck trailers, it's my only heavy rated trailer.
   / trailer ball capacity / shank size #14
Anyone ever busted their ball?
A buddy of mine came by just a few weeks ago and opened my eyes to the variety of capacities these balls can carry.
   / trailer ball capacity / shank size #15
Good thread here as I'm betting most everyone on this sight at least slightly exceeds your standard off the shelf ball you can pick up at tractor supply.
I was shocked the first time I looked at the weight ratings for 2 5/16 balls off the shelf.
   / trailer ball capacity / shank size #16
I'm going to pay more attention to some of the 12,000-14,000 lb. trailers I see being towed and parked. Try an look at the hitch and educate (or learn).
What is the trailer weight rating (without equalizer) on factory hitch 3/4 ton trucks? Haven't looked at them for a long time and can't remember if the factory hitch would be OK for 14,000# bumper pull without equalizer. The thought of 14,000# on a 6000# ball (Reese stainless) is still scary.
My main trailers I own/tow are an old 12 foot dual axle skid loader trailer and a single axle equipment trailer with my 1/2 ton. I do have a 27 foot boat (4 cylinder gas) that was set up for an equalizer hitch that I only use the regular ball mount to tow it 30 miles twice/year. Haven't towed it for a few years. The 23 foot boat I do use puts me right at legal limits and I've been a little over combined gross on very long trips. That trailer needs a equalizer hitch mounted on it which I've bought and haven't put on (Pole tongue adapter).
I now have a 2001 Ford 1 ton single rear wheel truck I set up for an Alaskan truck camper that has steel utility box and front winch. Old railroad electricians truck. I have it loaded at max rating and would like to have 19.5 tires but rims are not available for it (that I found). Haven't needed to use it for towing yet. Just plan on using it for smaller boats but need to make sure it's ready if I tow the big boat.
I am a truck driver and more careful (safety type person) than most.
Dan
   / trailer ball capacity / shank size #18
And how many of you have the tools to torque these fasteners properly...
   / trailer ball capacity / shank size #19
I recently got a 30K ball and a 2 1/2" ball mount which is good for 18K. I have a class 5 hitch too. Overkill doesn't hurt when it comes to safety.
   / trailer ball capacity / shank size #20
I bought a torque wrench that I keep in my tow vehicle just to make sure the ball is secure.
Some of my hitches have no-rotate balls and have yet to find one loose... also, a fresh lock-washer does a fine job when used.
I have an eclectic assortment of trailers and tow with the following size balls:
1" (Single Wheel Camp trailer from 1957 that uses two 1" balls)
1 3/4" (Around the yard)
1 7/8"
2"
2 5/16"
2 1/2" inch on a custom trailer built in the 1930's... hitch, ball, trailer were all custom made.
WB Mower (A50120)
WB Mower (A50120)
2009 Utility Trailer Mfr. 53ft. T/A Dry Van Trailer (A55852)
2009 Utility...
2018 GENIE GTH-5519 TELESCOPIC FORKLIFT (A52706)
2018 GENIE...
2013 Ford F150 4X4 Pickup Truck (A53422)
2013 Ford F150 4X4...
2014 Ford F-450 Dump Truck, VIN # 1FDTF4GT9EEA61310 (A54865)
2014 Ford F-450...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A56129)
2006 KENWORTH T800...
