trailer ball capacity / shank size
/ trailer ball capacity / shank size #21
Capt. Dan,
Good point. Let me share a story with you.
Recently, My cousin asked me to move a large travel trailer (park model) for his grandson. Dry weight on the trailer is over 11,000#. I told him that we needed a Class 5 (15k) ball and ball mount. (my F-350 has a Class 5 hitch) He asked, "What for? NOBODY uses stuff like that." I explained that I would not move the trailer without the proper ball and mount. (I didn't have one because all my heavy trailers are G/N) He grumbled around for a few days and then ordered one. Then, I gladly moved the trailer for them.
Point is, I don't think MOST people understand the difference in towing equipment, or even know what they have.
Again, good topic. Maybe someone will read this thread and avoid future problems.
/ trailer ball capacity / shank size #22
Etrailer.com 2 5/6 balls by capacity:
Gross Trailer Weight Capacity
10000 lbs GTW (14)
12000 lbs GTW (6)
14000 lbs GTW (3)
15000 lbs GTW (1)
16000 lbs GTW (1)
2000 lbs GTW (3)
20000 lbs GTW (8)
24000 lbs GTW (2)
25000 lbs GTW (5)
30000 lbs GTW (20)
6000 lbs GTW (1)
7500 lbs GTW (1)
8000 lbs GTW (2)
2-5/16 Inch Diameter Ball Balls | etrailer.com
Bruce
When I was looking it was back in 2007 and they were very scarce and only found the REESE PRO SC equalizing hitch rated for 14k and had to add the Super Hitch receiver for the 15k rating, now all the big 3 have the 2 1/2 hitch receivers.
David Kb7uns
/ trailer ball capacity / shank size #23
Neighbors Suburban came with a 2 1/2 reciever from the factory... at first he was a little miffed about it because he had everything for the 2"
He tows about 600 miles a week and looking back appreciates the heavier components.
I'm guilty of this and have to learn how you quote.
"Originally Posted by tcartwri View Post
And how many of you have the tools to torque these fasteners properly..."
I've have never put my old 1/2 inch beam torque wrench to a trailer ball. Need to check it's capability. Usually put mine on with a 24 inch long breaker bar. Don't think I've used a cheater bar to install a ball. Am I getting a 1 inch shank close to torque? How often do they get over torqued?
I have stopped cars twice for a loose ball. Once was in Utah towing a U-haul to east coast.
Dan
/ trailer ball capacity / shank size #26
Or even know the specs?
My 14K equalizer
Hitch balls require a 1-7/8 socket and a torque wrench capable of
approximately 430 ft-lbs torque for installation
So I just put a 24" bar on the big socket and put most of my weight on it
Dan
A torque wrench for 430 ft lbs to be used once a decade is expensive.
/ trailer ball capacity / shank size #27
Actually got the Harbor Freight 3/4 socket set for this and put the stinger in the receiver on its side and step on the wrench handle until tight, think one of the balls had a spec of 480ft lbs so 2 foot handle and 240lbs will do it.
David Kb7uns
/ trailer ball capacity / shank size #29
Well, I'm down to one hitch brand. B&W, I've got a flip over with a 2 and 2 5/16 rated for 10,000 pounds and 1000 pound tongue weight, that's fully height adjustable, and a flip- over gooseneck from them. There stuff is top quality. LUTT
/ trailer ball capacity / shank size #30
I think for some folk "I can't bend it by hand" becomes "It can't be bent". Sadly, there's a vast spectrum above that demonstrated daily in "accidents".
/ trailer ball capacity / shank size #31
I bought a torque wrench that I keep in my tow vehicle just to make sure the ball is secure.
Some of my hitches have no-rotate balls and have yet to find one loose... also, a fresh lock-washer does a fine job when used.
I have an eclectic assortment of trailers and tow with the following size balls:
1" (Single Wheel Camp trailer from 1957 that uses two 1" balls)
1 3/4" (Around the yard)
1 7/8"
2"
2 5/16"
2 1/2" inch on a custom trailer built in the 1930's... hitch, ball, trailer were all custom made.
Actually, according to one NASA test conducted years ago on fastener thread locking mechanisms and processes, the so-called lock-washer came out as worse than useless. In other words, it performed worse than with no thread locking mechanisms or processes at all.
I know on the International Space Station, NASA forbade the use of lock washers; and, presumably, on all space flight hardware. A lot of those reasons had to do with requirements in addition to thread locking ability, however (i.e. off-gassing, FOD reduction, captive fastener requirements, etc.)
Unfortunately, I cannot find that test report (probably on my work PC and I'm retired now), but here's probably the next best thing: Pirate4x4.Com - Extreme Four Wheel Drive Specifically, read the bottom of page 12 in the .pdf.
I haven't used spring lock washers since at least the early '90's and I never will.
Good luck!
/ trailer ball capacity / shank size #32
Just out of curiosity does anyone know of a case where the ball or shank failed?
/ trailer ball capacity / shank size #34
David Kb7uns
Yup. We have a torque wrench at work that will do 600 ft.lbs and it's three feet long and I recall it was close to $700 a decade ago.
The lock washer is just there to keep the nut from completely falling off imo. It's the stretch of the shank that keeps the assembly together.
/ trailer ball capacity / shank size #35
Excuse me... it was $1900 :confused2:
/ trailer ball capacity / shank size #36
The set of balls I bought when I bought my truck in 1985 all had split lock washers... the 2000# 1 7/8, the 3500# 2" and the 10,000 # 2 5/16
I've noticed a 1" washer will physically tear metal off the mating surfaces the first time taken apart.
Could be I'm working with old data?
My antique cars all have Castle Nut with cotter pins everywhere... about the only place a modern car may have this is at the wheel bearings.
Also a big fan of the various thread lockers... although I have never used one on a trailer ball.
I did have a trailer come loose once and it was my fault for letting someone else hitch it up to the truck.
Back then, I used Convert a Balls because no tools needed to change ball sizes... the 1 7/8 ball got a lot of use from the box trailer and the locking pin that holds the ball to the shank was no where to be found when the trailer with ball came off the back of the truck.
My best guess is when my helper changed the balls the pin slipped out and not knowing it was missing, set the ball on the shank...
Lucky nothing was damage... again, very lucky!
Ever since then I personally check the mount before driving off... heard to many stories where people have hitched up and come back to find something amiss.
A friend had similar and the reason is someone had tried to steel his trailer... the coupler was open and the one of two safety chains without a lock was dragging... without the lock he could of lost the trailer two ways... theft or going down the road.
/ trailer ball capacity / shank size #37
I slide the hitch in sideways into the mount then put my 3/4" drive HF socket on it and a 4' cheeter bar and use my weight to tighten the balls.
before I had my 3/4" drive HF set i used a pipe wrench and cheeter bar.
"Just out of curiosity does anyone know of a case where the ball or shank failed?"
I've only heard of the balls loosing the nut and lifting off the hitch. It happened to a friend of mine when he hit a bump at a bridge. With a heavy 26 foot trailer.
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
2025 Ariens IKON 42 42in Zero Turn Commercial Mower (A59228)
2025 Ariens IKON...
2007 Ford F-250 4x4 Crew Cab 7ft. Flatbed Truck (A59230)
2007 Ford F-250...
BUSHHOG RMB1865 DITCH BANK MOWER (A60430)
BUSHHOG RMB1865...
2017 Wacker Neuson LTV6 Towable Light Tower (A56857)
2017 Wacker Neuson...
Hydraulic Liftgate (A59230)
Hydraulic Liftgate...
