Oil & Fuel Runs and then Quits or Won't Restart Unless I...
   / Runs and then Quits or Won't Restart Unless I... #1
Scooter74
Rogers, Arkansas
Branson 3510 (20040
A Branson 3510 10 years old. First time for this problem. When I can get it running it seems OK but then will quit or 'stumble'/lose power and nearly stop. When I try to restart it I have to bleed the system starting at the Injector pump bleed nut and then at the head bleeding one injector.
History: When I first tried to run it after about 3 months of not using it the Fuel Gauge showed empty and it would not start. I put in 5 gallons and bled the system as I have before just bleeding it at the bleed screws on the fuel filter. (This also concerns me because I know better than to leave an empty tank and normally add a fuel stablizer for the winter months. No evidence of a leak on the barn floor under the tractor.)
It started but after running about 30 minutes it stumbled and then restarted and then stumbled again a few minutes later. (We had a Wood chipper/shredder attached to the PTO but there was no overload condition shredding leaves.
We quit for the day and then next day or so I tried to start it again and had to then go through an extended bleed process using the fuel injecter 'Air Breather Plug" and then bleeding at one of the injector lines on the cylinder head.
Am I doing something wrong that is leading to a ongoing fuel flow issue or do I have a failing part such as the electric fuel pump.
I read another thread with a somewhat similar issue but not exactly the same conditions.
Perhaps its moisture built up over the winter but then why will it run fine after bleeding and then suddenly quit. So far I just replaced the fuel filter figuring that was due anyway.
Open to suggestions, obviously. I don't want to start replacing parts searching for the answer. BUT I suspect the fuel pump needs to be tested and possibly replaced if I have to start somewhere. I also, after reading the other thread am looking at blowing air back into the tanks to make sure they are clear but again if there is something in the tank that would just temporarily relocate it.
   / Runs and then Quits or Won't Restart Unless I... #2
Remove fueltanktap and clean aswell as liftpump screanfilter . bleed and try again
In Searching for a new fuel pump, if needed, I see two options, one online source and my local dealer. Online $107.95 "On Sale" local price, yet to find out. Anyone tried a 3rd party pump. I found one or two out there that seem to be good match up and at about 1/3 the price.
   / Runs and then Quits or Won't Restart Unless I... #4
Try disconecting the fuel return line from the fuel tank and from the filter assy and blow it out. That worked for my New Holland tractor. (I assume there is a return line on yours.)
It start every time when its cold ?
Nope. Once you stop it you have to bleed the system again. Somehow it seems to be getting air in the system. Fuel Filter remains full looking.
Looks like I'm going to test the fuel pump once our rain stops and force air pack into the tanks to clear any possible clogs.
   / Runs and then Quits or Won't Restart Unless I... #7
I think Trekkers is onto something - if the fuel tank vent in the cap is plugged the tractor while running is creating vacuum which may cause the fuel not to run to the pump. Then either vapors or air is getting into the system causing the pump to lose prime. Will it run without the fuel cap?
Actually I don't believe the cap itself has a vent but I'll check the tank vent pipe and make sure that it's clear. Drawing from the Parts, Operators, and Maintenance manuals aren't that impressive for details and with the usual poor translations into English it's not always clear what to do or what parts are where and their names.
   / Runs and then Quits or Won't Restart Unless I... #10
When blowing your fuellines .... do not blow the dirt back in your tank ......disconnect both ends !
Case International 3450 Round Baler (A51573)
Case International...
Electric Forklift Pallet (A50322)
Electric Forklift...
2020 COLOMBO TM LOT NUMBER 216 (A53084)
2020 COLOMBO TM...
2014 RAM 5500 Bucket Truck - 4X4 - Cummins Diesel - Automatic Transmission -Versalift SST40 Boom (A53472)
2014 RAM 5500...
2021 JOHN DEERE CP690 LOT NUMBER 196 (A53084)
2021 JOHN DEERE...
