2004 z-master commercial zero turn with kohler sp27 engine problem
   / 2004 z-master commercial zero turn with kohler sp27 engine problem #1
fphipps
granite falls, nc
toro 74243
I purchased this mower used a couple of years ago. I was mowing with it when it started losing power, and kind of spitting or lightly backfiring? I tracked it down to one side of the twin cylinder. pulled the plugs, that side was blackened up from misfiring, checked compression both sides 120 lbs, checked the ignition module on that side with normal ohm readings, so i think maybe its the spark advance module?? Anyway i checked with my local Toro dealer for the spark advance module and found out it is no longer available part #24-584-27-s. I am just wondering if there is a replacement part I can use. I know they make a digital module. Any help with this problem will be appreciated.
   / 2004 z-master commercial zero turn with kohler sp27 engine problem #2
Could be just a bad spark plug. Before I would go changing other stuff, I would put some new plugs in both cylinders and try it. I had plugs in my boat that went bad just setting in my garage and would fire correctly intermittently and then just barely run.
I changed the plugs, didn't help. Thanks for trying!
   / 2004 z-master commercial zero turn with kohler sp27 engine problem #4
I had a Toro 60" zero turn that had a Kohler engine and mine did pretty much the same thing, it was a rocker arm but that worked loose. Worth looking into
2015 UTILITY VS2RS 53FT REEFER TRAILER (A53426)
2015 UTILITY VS2RS...
WINDLASS 5 HEAD (A53843)
WINDLASS 5 HEAD...
2020 KOMATSU PC360LC-11 EXCAVATOR (A51246)
2020 KOMATSU...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
John Deere Gator XUV835M 4X4 Utility Cart (A48082)
John Deere Gator...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
