4' King Kutter mfg brush cutter gearbox
   / 4' King Kutter mfg brush cutter gearbox #1
CCarr1945
Anderson Co., TX
1952 Ford 8N, Kubota 500
I have a 4' "Texas Red" brush cutter that says it was mfg by King Kutter.
I noticed the gearbox bolts have become loose.
The four nuts and the bolt that holds down the gearbox turn. I tried to tighten the nuts.
Under the mower is a "stump jumper" as they call it.
Are these bolts designed to be loose?
If not, what is the procedure to tighten them?
It looks like I would have to remove the stump jumper to get to the bolt heads?
   / 4' King Kutter mfg brush cutter gearbox #2
No, the bolts shouldn't be loose. You'll probably have to remove the large bolt holding the stump jumper, and blades in place...it's usually a tapered spindle, so it may take some effort.
   / 4' King Kutter mfg brush cutter gearbox #3
Try grabbing nuts with vice grip wrench and pull up on nut as you turn...sometimes bolt head will jam underneath enough to let you tighten....
   / 4' King Kutter mfg brush cutter gearbox #4
sometimes you can take an impact and tighten up bolts that spin. Just don't set the impact too high so that is will break the bolts if this does work. In other words set your impact on the lowest setting and put it on the bolt head and bump the trigger. The impact will spin so fast that sometimes the mass of the nut on the bolt is enough resistance to get the bolt to thread into the nut. Notice I said sometimes.. Can't guarantee this will work. But it doesn't cost much to try.. And if you don't have an air compressor and an impact.. Well, you need one. I have managed to take the fan nut off of a vacuum cleaner motor using this method, and there is no other method to do that.
Thanks to all! I took it to the dealer who sold it to me years ago. One hour labor to remove the stump jumper and replace four bolts, sharpen blades and lubricate back wheel and gearbox. Runs smooth now. Only problem was forgot my money and had to make two 40 mile trips. :duh:
2018 Kubota L4701 (A50120)
2018 Kubota L4701...
2006 KENWORTH T800 TANDEM SLEEPER TRUCK (A52141)
2006 KENWORTH T800...
2019 Ford F-350 XL (A50120)
2019 Ford F-350 XL...
KJ 12'x20' Single Garage Metal Shed (A50121)
KJ 12'x20' Single...
2015 Kubota RTV-X1100C (A52748)
2015 Kubota...
JLG ELECTRIC MANLIFT (A52472)
JLG ELECTRIC...
