Nightmare senario...lost my oil plug and oil
   / Nightmare senario...lost my oil plug and oil #1
maddog69
Member
Kubota BX 2200 in Pa. Kubota Bx 1870 Fl.
I put one of those rubber plugs in because I stripped my oil drain bolt....and blew the plug out. Lost my oil, the tractor started running funny and stalled. This was after probably about I would guess from tracking the oil trail, about 3 or 4 minutes without oil. I will have to put the stripped bolt back in and replace the oil to see what the damage is. Do you think I wrecked my engine? Thanks Brad
   / Nightmare senario...lost my oil plug and oil #2
not good...sorry
I put the stripped bolt in, filled it with Rotella, and it sounds fine. Just wondering if I shortened the life of the engine....
   / Nightmare senario...lost my oil plug and oil #4
I'm impressed...you must feel every relieved.
I wouldn't worry about too much engine life...it is what it is.
You might want to properly fix that stripped bolt thing.
Good luck!
   / Nightmare senario...lost my oil plug and oil #5
Maybe there's a low oil shut-off to save the engine in just such a matter....?
   / Nightmare senario...lost my oil plug and oil #7
Yes, you shortened the life of your engine. It would be hard to tell by how much without tearing it down and going through it, which doesn't make sense. Repair the drain plug issue properly and keep a close eye on the oil and plug.
   / Nightmare senario...lost my oil plug and oil #8
Yes, you shortened the life. Depending how long you keep it, it might not affect you for years. Find someone to install a heli-coil in it, pronto!
   / Nightmare senario...lost my oil plug and oil #9
I once had a mower that ran out of oil and stalled. Refilled started and sounded good. A month later KABLOOOEY ......... BIG hole in the block . Hopefully it does have a low oil shutdown.
I wonder if it does have a low oil shutdown as it just reved a couple of times and died....
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
2019 CATERPILLAR 279D SKID STEER (A51246)
2019 CATERPILLAR...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
UNUSED HURRICANE D6028 JOB BOX (A51248)
UNUSED HURRICANE...
Two Post Car Lift (A50120)
Two Post Car Lift...
UNUSED WOLVERINE TL-12-72W - 72" HYD TILLER (A51248)
UNUSED WOLVERINE...
