MF 31 sickle bar mower - Hinge bushing 581324M1
   / MF 31 sickle bar mower - Hinge bushing 581324M1 #11
Couldn't find a PTO drive that went to 1" shaft with 1/4" shearbolt. Since I have the mower half, I bought a the tractor half on eBay. I don't know what it's like inside, and assume I'll have to fabricate the 7/8 x 3/4 rectangular socket part. How much engagement do you think it needs? The shearbolt is only 1/4".
4" or so.
Thanks, that should be easy. Is there a grease fitting at the middle of that 4"?
   / MF 31 sickle bar mower - Hinge bushing 581324M1 #13
Here's what my rig looks like
Only zerks are on the U-joints.
Good luck
Good, thanks. I suppose you just pull it out and put some grease on it if dry. I'm still waiting for my shaft - almost ready to crank this thing up!
   / MF 31 sickle bar mower - Hinge bushing 581324M1 #15
Drill a hole in the collar for a zerk and a few holes or a groove & some small holes in the sleeve, for grease to pass through.
2016 FORD TRANSIT 250 VAN (A51406)
2016 FORD TRANSIT...
2018 Toro Grounds Master 7200 72in Zero Turn Commercial Mower (A50322)
2018 Toro Grounds...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
2017 Dodge Charger Sedan (A50324)
2017 Dodge Charger...
2022 BANDIT 2550TK STUMP GRINDER (A51242)
2022 BANDIT 2550TK...
2015 FREIGHTLINER M2 DAY CAB (A51222)
2015 FREIGHTLINER...
