LD1
Epic Contributor
Really appreciate all the opinions and information provided by the members, I can be really stubborn about some issues. BTW, the 2002 John Deere 4000-Ten series brochure lists the following figures:
Mowing 2 acres: 18 horsepower 4010 with 60 inch deck, 48 minutes
32 horsepower 4310 with 72 inch deck, 40 minutes
48 horsepower 4710 with 72 inch deck, 36 minutes
Top speed of the 4310, which is the next model up from mine is listed at 15 to 17.5 mph, depending upon tire size and transmission type. A 4710 would be as fast or even faster than the maximum 17.5 mph of the 4310 and have a 1 foot wider deck than the Exmark I decry but Deere rates it more realistically at 72 minutes for 4 acres.
Trying to reverse figure those numbers, using the 4710, I am figuring that out to be 3.33 acres per hour.
With a 6' deck and 80% efficiency, you would have to be travelling 5.7 miles per hour.
And in all honesty, with a tractor in lieu of a ZTR, if you have things to mow around you will likely be less than 80%.
I think with a ZTR, you can get alot closer to 100%. You have better visibility IMO to make each pass closer to 72" of work withuout loosing due to overlap.
Again, I dont really see the fuss. ZTR's are listing max. And anytime things are listed maximum capacity, they are assuming optimum conditions. So if ZTR A claims 10mph and can do 5ac/hr, but you know you have a very rough yard or often let it get ahead of you, and know you can only travel in the 5mph range, you know you are only going to get about 1/2 of its rated acres/hr.
Here are my thoughts on things like this in general....and this is in no way a pun against you JD:
But issues like this make me think that consumers are just too stupid anymore. And lack the basic understanding to apply basic math to get to real world examples. Real world is different for everyone. Again, grass height, finished height, yard conditions, obsticals, etc all play into how fast a mower can mow. So listing a max is a good baseline. And really only tells you one thing when comparing mowers if the decks are the same width, it tells you which one can go faster. Weather or not your lawn can allow it, doesnt mean someone elses can or cant.
And you know, they never even used to rate mowers on an acre/hr basis. But again, cause consumers are too ignorant IMO, they need these things spelled out for them. Its quite simple actually. Wider decks mow more area faster. And higher blade tip speeds allow you to travel at a faster ground speed and still leave a clean cut. So as a consumer, if comparing two mowers with same size decks, if I know I have a rough yard and can rarely go over 5-6 mph, I certainly aint gonna look at what they rate them on an acre/hr basis. Cause I know I cannot attain that and all it will do is tell me which one has a higher top speed. Rather I would look at blade speed, and whichever is higher is likely gonna leave a cleaner cut and/or allow me to go a little faster.
