3016 Mahindra, Adjust Clutch
   / 3016 Mahindra, Adjust Clutch #1
TractorThom
Bardstown, KY
Mahindra 3016
I just bought a new Mahindra, the clutch pedal has about 1-2" of play until you feel pressure. Can any of you guys or gals give me some help on how to adjust the clutch on this tractor?
Thanks in advance.
   / 3016 Mahindra, Adjust Clutch #2
1 or 2" of free travel is about what you want.
Doesn't sound like it needs adjusted.
   / 3016 Mahindra, Adjust Clutch #3
yup, that's about where it should be.
I see, I was nervous because I have A LOT of hills on my property that require me to use the clutch way more than I want to. Plus since it was new, maybe the peddle is just getting "broken in"
I sure hope I would not have to adjust it with less than 100 Hours. Is there a check I should be doing or a is there a way to gauge the need to adjust it?
   / 3016 Mahindra, Adjust Clutch #5
As a clutch wears with use, the pedal will rise. You'll know when it needs some adjusting when the 'freeplay' at the top decreases to little or none.
They don't often need adjusting until many many years have gone by.
   / 3016 Mahindra, Adjust Clutch #6
Yes, just keep it at around 1 to 2" of free travel.
If your free travel gets to be less you may need to adjust
   / 3016 Mahindra, Adjust Clutch #7
using the clutch won't hurt it, riding or slipping the clutch will. don't rest your foot on clutch pedal
2012 Manitex 50110SHL 50-Ton Boom Crane Truck (A53117)
2012 Manitex...
2017 Ford F-150 4x4 Ext. Cab Pickup Truck (A51692)
2017 Ford F-150...
FAE UML/SSL 150 VT QUICK ATTACH HYD MULCHING HEAD (A51406)
FAE UML/SSL 150 VT...
2016 John Deere 35G Mini Excavator (A52377)
2016 John Deere...
2023 Jeep Compass Trail Hawk 4x4 SUV (A51694)
2023 Jeep Compass...
2009 GMC Passenger Van, Vortec Engine (A52384)
2009 GMC Passenger...
