Water in fuel tank
   / Water in fuel tank #1
Mowbizz
Lakes Region, NH
'14 Kubota BX25D
Hey...brand new BX25D here...no problems with it but filled the tank today and was thinking of other things and left the cap off for a few hours...yup, you guessed it...rain shower came along.
Anyone know what I can put in there to absorb the water? Not sure if dry gas would hurt diesel?
Tank was full and the shower wasn't a downpour or anything but it did rain for a while.
   / Water in fuel tank #2
Check your local auto parts store or truck stop for a diesel additive that removes water. I think Power Service is one brand. Just read the labels. A light shower probably didn't get much in the tank.
   / Water in fuel tank #3
Does fuel tank have a drain to remove the water? a lot of tractors do.
   / Water in fuel tank #5
Tx Jim gave good advice. Inspect the bottom of the tank for a drain plug. If it has one, park the tractor in a position that puts the drain at the lowest point. Allow the tractor to sit still for a little while, and the water will settle to the bottom. Open the drain, and slowly let the water out. You will get some diesel too, but that's unavoidable.
If it doesn't have a drain, then a diesel fuel additive is your next best solution. Just realize, water won't pass through your fuel filter, so you'll probably need to change it soon.
Either way, you need to go ahead and get a couple extra fuel filters. It doesn't take much water to block a diesel fuel filter. They're designed that way. (you really don't want water in your injector system) And, it's good to have an extra filter on hand. Sometimes you just get bad fuel.
   / Water in fuel tank #6
Just get siphon hose to drain the tank. Peace of mind is worth a lot more than a few gallons of diesel fuel.
   / Water in fuel tank #7
Best to drain and filter through a MR Funnel or other water separator, most fuel additives will emulsify the water and it WILL get sucked through the BX inline filters. I added a B series water separator on my BX2230 and it is catching the excess water not being picked up by the additive and this is all going through the first inline before the fuel pump, so a water separator makes a difference.
David Kb7uns
   / Water in fuel tank #8
Mowbizz
Kiubota parts schematics list "no water drain" on your tractors fuel tank.
Mowbizz
Yup...I've been searching online and there are a number of "fuel dryers" for diesel out there...going to go with these. I don't think too much got into the fuel anyway so that's the plan for now. Thanks for researching the schematic for me!
I'm also going to order a Mr Funnel as well...looks like a good product!
Went to my local hardware store and was surprised to find a few "drygas" products for diesel...bought some of this and a fuel conditioner for continued use year round.
Thanks for the suggestions! I'll report if any problems ongoing.
ASSET DESCRIPTIONS & CONDITION (A52141)
ASSET DESCRIPTIONS...
2013 F-550 Bucket Truck (A52128)
2013 F-550 Bucket...
2018 FREIGHTLINER 1085D DUMP TRUCK (A51406)
2018 FREIGHTLINER...
New Power Line 400 Plastic 3pt. Spin Spreader (A50774)
New Power Line 400...
New Kivel Single Skidloader Spear (A50774)
New Kivel Single...
2014 Ford F550 4x4 Bucket Truck with Versalift SST40 - 45FT Working Height (A52128)
2014 Ford F550 4x4...
