New Ford 8N owner
   / New Ford 8N owner #11
this seems odd - positive ground - I am an engineer and the terns often thrown around are opposite of what some might otherwise understand - I have been around old red belly Fords not on this particular problem though and I am struggling to believe it is a positive ground - for sure the generator ought to be correctly wired in whatever the system ground - there is not a lot of stuff on one of these - if the lights are all turned off and the tractor is turned off - as one of the others has mentioned, there ought not be any current flowing...
Well.. apparently you aren't familiar with many machines from the 30's thru 60's... as stated.. those old fords that were 6v DID INDEED have battery positive polarity tied to chassis.
soundguy
   / New Ford 8N owner #12
I am sure there is reasons, and sure others know, but I dont know why they did it that way, .
The top of my list would be thermionic emission.
   / New Ford 8N owner #13
I have a piece of junk lawn-mower that does that. I just put a wing nut on one of the battery terminal screws so I can quickly pull it after each use. .
Why not buy a high current diode and wire it inline with your charge device as isolation from discharge? ( unless you have one of those nice starter generators. :)
   / New Ford 8N owner #14
I had 1/4-20 wing-nuts laying around and have no idea what a high current diode is. Electric ain't my thing and the less I fart around with it the better.
   / New Ford 8N owner #15
diodes are 'essentially' 1-way current check valves. ie.. current flows one way.. not the other... thus if you had a seperate dynamo etc. you could charge thru the diode to the battery.. but not let it reverse flow.
obviously this only works with a seperate charge device..
if ya don't like electrics. i don't reccomend changing from the tried and true wing nut.
   / New Ford 8N owner #16
you are right about the depth of my familiarity with those old ones - but the way to solve the problem still doesn't change and there can't be a whole slew of options that can be dragging it down - but there may be a worn insulation spot hitting the ground
   / New Ford 8N owner #17
my comment was directed at your mention that you were struggling to believe that it was positive ground.
fords that were 6v ( 1939 thru 1964 gas ) were positive ground.
fords that were diesel ( 59+ ) and all 65+ models were 12v neg ground.
MANY brands of tractors used positive ground schemes thru the years.
   / New Ford 8N owner #18
I finally figured out the battery drain issue on my new "lemon" lawnmower. It turns out there really was no problem there. I have cut the lawn with it for the 5th time now, and in the late afternoon, for the first time. It was kind of dark, when I backed it into it's resting place in my barn. The guy I bought it from, incorrectly installed a new drive belt when the original busted at 5 years of age. That is a tortuous 8 hour job, even for a good mechanic, requiring tearing half the tractor apart. The problem due to the incorrect assembly, is the brake does not function at all, and the tractor cant even be shifted into neutral with the motor running. It is hydrostatic, and, when idled down all the way, can be shifted from forward to reverse, directly, or vise versa, but it still moves at a snail's crawl. With the motor off, it can be shifted into neutral.
The first time I tried to store it, I ended up hitting my boat, pushing it a ways, before I turned off the key to stop it. Only because the tractor has a nice soft rubber, energy-absorbing grill, was no damage done. The next several times, I figured out that I could stop the tractor by using a "safety" feature, that shuts down the motor immediately if the mower is engaged while in reverse. I simply put the throttle in the lowest position, backed into the barn with the mower not engaged, and engaged it when I got to where I wanted to leave the tractor. That worked like a charm, but that is also when the "battery draw" began. As it turns out, I would always leave the key in the "on" position when I did that, because the engine was off, and I forgot to turn off the key. The tractor has another "safety" feature - full time headlights. It was always around noon when I backed in to store, real bright out, so I had no idea that the lights were on. I suppose it only takes them an hour or so to empty the battery all the way.
I only let the battery drain once, before going to the "wing-nut" trick on the terminal. Turns out I don't need that afterall. Now I always remember to turn off the key after stopping the engine (and wheels) with the reverse/mow safety. The seller must have worked a while to get the brakes adjusted enough to stop the machine when I did my test drive. I tried adjusting them again but no luck. The only thing I can say good about that tractor, is it does get the lawn cut in about half the time as my 30 year old gear-drive tractor, with the same width 48" cut, and it leaves it "smooth as a carpet". If I can get a season or two out of it, I guess I wont be too far behind. I am certain it will never go more than 30 like my old one has. Maybe I will get a little better life out of the drive belt than the original buyer did due to the "incorrect assembly". Clearly, a design that fails a drive belt at 5 years is a bad one. Maybe that "lemon-seller" figured out a way to improve it a bit. Cutting the lawn is one job I don't enjoy, but it sure is a lot nicer with a hydro, even if it is a "lemon".
2001 Acura MDX (A53424)
2001 Acura MDX...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
2025 JOHN DEERE Z325E LOT NUMBER 84 (A53084)
2025 JOHN DEERE...
2013 International DuraStar 4300 Crew Cab Mason Dump Truck (A51692)
2013 International...
2022 Gravely Pro-Turn 600 Zero-Turn Mower with 72-Inch X-Factor 3 Deck (A55218)
2022 Gravely...
2017 Caterpillar D5 K2 LGP (A55218)
2017 Caterpillar...
